Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › What’s Up at GuitarPCB?
- This topic has 16 replies, 9 voices, and was last updated 5 years, 2 months ago by
September 1, 2021 at 7:51 am #20419
BarryKeymasterThere are a lot of things going on behind the scenes lately.
So here is what to look forward to in the very near future.
- Updated Off-board wiring and Pads.
2. Some boards are being redesigned to feature on-board pots that were not originally.
3. Check out the new pads for 3PDT Wiring Boards, Buffer Boards, Buff N Blend and After-blaster.
(note the gentle curves)
4. Additionally all upgraded boards will use the 1N5817 diode for protection.
If you have any thoughts or questions feel free to ask.
September 1, 2021 at 7:14 pm #20432
Big OParticipantThe changes look great! It will be great to be able to use board mounted pots with the new larger off board pads. This saves lots of time wiring up pots.
September 4, 2021 at 8:39 am #20506
BarryKeymasterThanks Big-O.
September 5, 2021 at 12:22 am #20516Anonymous
GuestOther goals of the redesigns include:
Maximizing the width of the enclosure that we expect each build will be placed in. If it is going in a 125B, the new boards are more likely to be at least 2 in wide, sometimes up to 2 3/8 in. wide. By using the additional width, the hope is to keep the boards shorter and allow the use of side jacks or top jacks on most projects.
To provide as consistent as possible spacing of potentiometer holes from one project to another. Not only will this make it easier one builders, but also on kit providers like myself.
Longer runs of similar components or similar component shapes. For example, boards will have a long row(s) of resistors/diodes. Capacitors with outside pins .2 in (~5mm) apart are likely to be placed in a row with transistors which have the outer pins .2 in apart. This is to give this projects a cleaner appearance.
Many circuit boards also will have the shorter components near the top of the layout, making it easier to use narrow top jacks in the eclosures that might overlap the top of the board (in deeper enclosures like a 125B).
In some cases, additional markings are being made on the PCB to help the Builder understand things like which side of the circuit board a component is mounted to. Some early projects show the screen print around PCB-mounted jacks on the top of the board, when those actually mount to the bottom of the PCB. Some of the 3pdt switch boards now state things like, “Mount switch on this side”. Yes, we’ve seen some very frustrated new builders over the years. Hopefully some of these new markings will avoid a few of those past issues.
Like Barry, I certainly hope that everybody enjoys these new enhancements to our circuit boards!
September 5, 2021 at 4:39 am #20519Anonymous
GuestBut what will I do with all my extra time if I’m not hand wiring pots? Looks Great Barry, can’t wait to get some of the new boards, although I have about 20 or so floating around in my stash and ordered more yesterday.
September 12, 2021 at 8:01 pm #20579
BarryKeymasterSeptember 13, 2021 at 2:20 pm #20586Anonymous
GuestThose look fantastic Barry!
September 13, 2021 at 2:35 pm #20588Anonymous
GuestIndeed! Wonderful improvements! Kudos to Bruce too!
September 13, 2021 at 7:02 pm #20594Anonymous
GuestAbsolutely, wonderful work Bruce!
September 14, 2021 at 1:52 am #20606
mybudModeratorFunkadelic! Boards look really good. Congrats Barry and Bruce.
September 15, 2021 at 11:38 pm #20665Anonymous
GuestBarry,
Just looked at your new instructions and noticed that you have the battery black going to the sleeve instead of the ring in the illustration. Other than that, it looks very good.
Jay
September 16, 2021 at 7:19 am #20669Anonymous
InactiveThanks for these updates !
As an IT engineer, I know the tiniest, less visible changes are often the greatest ones 😉
This also is a mark of great involvement in your products. Keep it this way !September 16, 2021 at 6:42 pm #20677
BarryKeymaster@ Aviator Thanks for the update that is obviously very good to know and why I am putting this stuff out there.
That will be a quick and easy update. I award you with a new Avatar, Aviator.
So what do you guys think of the Populated Board image for troubleshooting purposes?
September 16, 2021 at 8:16 pm #20678Anonymous
GuestThat is just ANOTHER great idea that will facilitate construction and minimize troubleshooting. Actually, I have noticed a big REDUCTION in troubleshooting requests over the last few years. That just means that Barry’s Build Documents are getting better all the time. Bravo!
September 16, 2021 at 9:55 pm #20684
BarryKeymasterThanks Wilkie and Gus!
Here are the current four complete build documents for our 2021 Boards
Please check them out. I hope the resolution is good also while still maintaining a relatively small file size.
September 17, 2021 at 3:14 am #20700Anonymous
GuestHi Barry, I noticed on the Tube Screaming Ultra buld doc it says that the stock build is the Landgraff. To make an 808, it notes which parts need to change, but they are the same values as the Landgraff (I think). Cheers!!
September 18, 2021 at 5:47 pm #20734
BarryKeymasterUpdated now to include The Vibe, SHO’ Nuff, Tight Box plus any corrections.
Note that all Docs are also on the Guides Page and Shop links.
@ Jon you are correct. I updated the Doc. Thank you for that!
