Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Problem with Mini Me (solved)
- This topic has 12 replies, 6 voices, and was last updated 6 years ago by
November 8, 2020 at 10:02 am #15673
InactiveI built a Mini Me Chorus Kit but it doesn’t work. There is no effect in the sound. I think the oscillator is not oscillating. I have a sheet with all the voltage accross the circuit that I should have and a lot are wrong. Can you help me debug this ?
Here is the schematic of the circuit.
Here is the sheet with all the voltages of the circuits (you can zoom in). If there is no actual voltage, that meens it’s correct.
November 8, 2020 at 11:57 am #15674
CybercowParticipantWe need good, clear, close-up photos of the work. Please show us photos of both sides of the PCB and ALL the wiring so we can clearly see what is connected where.
November 8, 2020 at 12:12 pm #15676Anonymous
InactiveHere are some pictures :
November 8, 2020 at 12:50 pm #15677
ChuckParticipantLooks like you need to connect G2 at the top left of the board (I know this because I missed it on my own build).
November 8, 2020 at 12:58 pm #15678Anonymous
InactiveI have a component leg accross the two sides of the board in G2 hole, do I need to connect to something else ?
November 8, 2020 at 1:35 pm #15679
PlaysforfunModeratorI think your red wire should go to the 9v pad but it looks like it goes to ground. No power?
November 8, 2020 at 1:59 pm #15680Anonymous
InactiveThe red wire goes to 9V and the green to GND, there is power on the board
November 8, 2020 at 2:25 pm #15681
PlaysforfunModeratorBuild doc states that D4 should have a diode or a jumper across the pads the way I’m reading it. I haven’t built the new board version yet.
November 8, 2020 at 3:13 pm #15683
BarryKeymasterInstall the diode at D4.
Be sure those pots do not short on the back of the board solder joints.
Hi Playsforfun! Welcome back.
November 8, 2020 at 3:24 pm #15684Anonymous
InactiveThanks PlaysForFun that was the problem, I ommited this part.
The last problem I have know is that the LED don’t light up. I’ve soldered as mentioned in the build doc but I have no red or green. I’ve checked the polarity. What voltage should I have on pins 1,2, 3 ?
November 8, 2020 at 3:58 pm #15685
BillyModeratorYour LED needs to be common anode, centre pin positive two outer pins ground
November 8, 2020 at 7:01 pm #15690
PlaysforfunModeratorGlad to help, eliobou. This chorus circuit is excellent. I keep one nearby always.
November 10, 2020 at 3:31 am #15706Anonymous
InactiveIt now works well thank you all guys !
