Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › Brand New NostalgiTone Releases + ROCK-Q Tone Module Updates
- This topic has 33 replies, 6 voices, and was last updated 3 weeks, 6 days ago by
September 10, 2026 at 3:49 pm #40512
BarryKeymasterThanks again to everyone who continues to support GuitarPCB and NostalgiTone. Every new project, build, order, and bit of feedback helps keep this whole thing moving forward.
Here is a brand new and exciting release.
NostalgiTone STADIUM ROCK
STADIUM ROCK is all about those big, saturated 1980s arena-rock tones. It’s a multi-stage analog overdrive/distortion with an active 3-band EQ, including a focused 800 Hz mid control that lets you push the mids forward for singing lead tones or pull them back for a bigger, heavier sound.
Think thick sustain, aggressive attack, and plenty of room to move from classic rock crunch to full-on arena-rock saturation.
Check out the video below for a listen.
Now lets discuss some of my new ideas! 😁
September 10, 2026 at 5:36 pm #40516Byrdhouse Compressor
ParticipantThese look (and sound) great! The Cock It Wah, Orange, and ModBender have been sitting in my cart for a while, but the bass PCB is a great excuse to finish the order. Question: would you say that the Stadium Rock is influenced by the Rockman tones? I see the Boston and Def Leppard mentions, and I’ve been interested in recreating that sound.
September 10, 2026 at 5:55 pm #40519
BarryKeymasterRecreating the Boston sound is a giant can of worms that I will be exploring. 😁
Does STADIUM ROCK have the saturation? Yes.
Does it have the 800 Hz mid focus, which is boostable with an active EQ? Yes.There is much more to the Boston sound than that, though.
If we’re talking specifically about the first Boston album, you have to consider that Tom Scholz wasn’t using Rockmans or RockModules in 1976-77. He was using a Marshall amplifier, which he boosted with a secret device that I have already designed and am currently waiting to verify when the PCBs arrive.
He also used an MXR 6-band Graphic EQ with very specific settings. And that’s all without getting into the compressor, chorus, and delay. I have left a few items out on purpose but you get the idea.
There’s also a fairly noticeable difference between the debut album and the follow-up albums, which became even more processed. aka; The Rockman sound.
What’s brilliant about doing it this way—keeping the pieces separate—is that you’re not locked into one band’s tone. A few quick twists of the knobs and you can move from one classic sound to something completely different.
So, in short, yes, you should get the STADIUM ROCK. 😁 It will give you the saturated Marshall-style foundation, with the added bonus of an active EQ with a focused midrange centered around 800 Hz.
It’s not intended to be the entire Boston rig in one box—but it’s definitely one of the important pieces of the puzzle.
September 11, 2026 at 1:25 pm #40524
BarryKeymasterAnd this is where the Boston rabbit hole gets ridiculous, and also where you discover that some of the details really do matter. 😂
Take the MXR 6-Band Graphic EQ. Scholz used the EQ as part of his setup, including using it to recreate the frequency response of his studio cocked-wah sound for live performance. So naturally you might think, “Fine, I’ll just grab an MXR 6-Band and dial in the same settings.”
Well… not quite that simple.
There have been several versions of the 6-Band over the years. The older blue version uses through-hole construction and TL022 op-amps, and these older units are known for having more character and breakup when pushed. Later versions, including the black 9V-input model and the current M108S, use newer surface-mount implementations and are considerably cleaner.
That matters when you’re putting the EQ in front of a Marshall and using it to push the amp. The EQ isn’t just shaping the frequencies; its own behavior becomes part of what is hitting the amplifier.
And suddenly you’re down the rabbit hole: which MXR, which revision, what EQ settings, what Marshall, what was in front of it, and what was happening after it? 😂
That’s not necessarily cork sniffing. If the older EQ actually breaks up differently and changes how it drives the next stage, that’s electronics, not magic.
And that’s exactly why I like approaching these classic tones as separate pieces. You’re not locked into one band’s tone you can experiment with the individual pieces and combine them in different ways.
Old Blue – (through hole components)
Newer versions Black and Silver – (smd will not allow that special thing to happen)
September 12, 2026 at 10:14 pm #40528
BarryKeymasterI was kind of hoping to continue the conversation here so if you all have any comments or questions go ahead.
So, regarding my previous post about one of the most crucial tone elements for Boston’s first album guitar tone, I’ve been working on an idea where I create my own modules. I may expand on that concept here at some point if there is some interest.
For now, I’ve developed a circuit based around the crucial analog, through-hole components of the MXR 6-Band EQ Blue Box version. Instead of using individual sliders, I’ve replaced them with resistors that provide a fixed level for each band, locking everything into the exact settings needed for the Boston tone. So all you have to do is turn it on and you’re good to go.
I also added a single Level control, which isn’t part of the original circuit, but I found it useful.
This would be one more module toward achieving that iconic Boston tone, while still giving you the flexibility to turn it off and play completely different styles. That’s something you really can’t do with a Rockman.
As mentioned in my previous post, the only version that can really achieve this is the Blue Box version, due to the older through-hole components used in its construction. Those components have a different character and add some extra breakup and harmonic character to the tone that isn’t quite the same in the later Black or Silver versions. Unfortunately, finding an original Blue Box version in good condition isn’t getting any easier, and prices have climbed considerably, with vintage examples commonly selling in the $175–$300 range and some asking considerably more. So rather than hunting down an expensive vintage pedal, I wanted to build a dedicated module that captures the important characteristics of that particular version and locks the EQ settings into the configuration needed for this tone.
Simply plug this in front of the Stadium Rock, your favorite high-gain pedal, or a high-gain amp, and you’re well on your way to some great Boston-style tones.
There will be more to follow if there is some interest.
September 13, 2026 at 10:21 pm #40532Byrdhouse Compressor
ParticipantThis was super awesome to come back to after a weekend vacation – I am definitely a beginner gearhead/circuit assembler and just now becoming familiar with the Rockman units that seemed to be very crucial to the 80s radio rock sound, with Def Leppard in particular. I had wondered “how hard could it be to just recreate that rack in a big pedal?” And then the rabbit hole began of looking at the different versions, looking at the schematics and components, learning about the different clean channels and I essentially gave up. But this is really cool to see that (if I’m understanding correctly) you’ve recreated that EQ profile, and the level adjusts the severity of the EQ? On a related note, I think I read that it sat in mixes extremely well as it was made for that reason and layering, and that a few guitarists back in the day were really excited to get that sound only to be disappointed with what they heard without other accompaniment.
September 13, 2026 at 10:49 pm #40533JasonWickersham
ParticipantVery cool EQ concept. I look forward to seeing this circuit evolve!
I’ll need to pick up this bass fuzz monsterpiece, I’m getting started early on Christmas gifts to my musician friends.
September 14, 2026 at 12:48 am #40538
BarryKeymasterYes, where the information can be verified, I have precisely recreated the artist’s EQ voicing as they used it. The Level control allows you to cut the output if it becomes too much when running pedals in tandem. That’s why I thought it was useful to have available. With the Level full-up, the ROCK-Q will be at the same volume level as the original MXR 6-band EQ, which does not have a separate Level control.
It’s also worth mentioning again that I’ve used through-hole ICs that will deliver the goods, something that isn’t possible with the later Black and Silver SMD versions.
Thanks!
The idea is that I’ll offer multiple BOMs for the ROCK-Q, allowing you to build your favorite artist’s EQ voicing from choices like Boston, Randy Rhoads, Dimebag Darrell, Michael Schenker, and of course Brian May though his specific tone is almost achievable with the STADIUM ROCK PCB alone. Simply cut the Bass, Boost the 800 Hz focused Mids, and Boost the Treble and Bob’s your Uncle. Anyway their specific EQ settings are well documented and recognizable, so each BOM would let you build the corresponding voicing.
September 14, 2026 at 12:56 am #40539
BarryKeymasterHas anyone said the name of this new circuit out loud several times?
September 14, 2026 at 8:52 am #40540
brdModeratorAwesome idea, Not too many players are going to change an EQ mid set. Some folks even tape them over to keep the sliders from moving.
The level control is a great addition, that is one advantage of a Boss EQ.
Hopefully it won’t be too hard to figure out the relation of the sliders to the component values in case you want to use 3 of these on your board. Put one on front for guitar tone shaping, another for post drive shaping and one at the end of your board.
September 14, 2026 at 1:16 pm #40542
BarryKeymaster@ brd
I’ll have a chart that makes it pretty easy to translate the slider positions into common resistor values, along with the preset combinations for specific artist EQ settings available in the BOM. The resistor positions can also be socketed, so anyone who wants to experiment can easily customize the settings and come up with their own. I think that could be pretty cool for people who like to tweak things beyond the standard settings.
Interestingly I am also working on an exciting new Compression module at this time as well.
September 15, 2026 at 9:28 am #40547Byrdhouse Compressor
ParticipantI agree with brd, it’s fun to mess around with EQ settings to find your sound (or in this case, famous player sounds), but once you’ve locked in to what you like, I’d imagine lots of people appreciating this set and forget method – “Hand me my EQ pedal, would you?” “You want the Rhoads version or the Dimebag version?”. It also might be easier than I think it is, but I love the idea of swapping out select resistors for different curves/frequencies, and once a builder feels confident enough in their circuit building skills, they can model their own profile.
September 15, 2026 at 1:23 pm #40549
BarryKeymaster@ Everyone
We’ve all spent countless hours chasing the exact tone of our favorite players, buying overdrive pedals and amp heads. But often, we try to get there using the limited tone controls built right into our guitar pedals. Most standard pedals limit you to a simple Tone knob, or perhaps a Bass and Treble control. Often these controls are completely passive. They can only cut your frequencies rather than boost them, leaving you stuck within a very narrow window.
But there is a foundational element that defines nearly every legendary guitar sound in history. It is an element that often goes completely unnoticed, and that is a highly specific, fixed EQ curve.
When you hear iconic players, you aren’t just hearing a high-gain circuit. You are hearing the magic of a precise frequency signature that cut through a mix. Michael Schenker did it by parking a physical wah pedal halfway through its sweep. Scholz, Rhoads, Dimebag, and many others did it by pushing specific sliders on graphic equalizers. They were using those filters to reshape how their guitar signal slammed into the amplifier preamp before the clipping even happened.
Fast forward to today, and the most popular gear revolution on the market is Digital Cabinet Impulse Responses (IRs). Every modeler and digital capture device relies on IR technology. But what exactly is a speaker IR at its core? It is essentially a high-resolution, static EQ curve that captures the exact physical resonant peaks and dips of a speaker cabinet, a microphone, and a room.
The goal of the ROCK-Q project is to bring that concept back into the physical world.
The best part is that aside from building an artist style tone direct from the bill of materials, you can easily create your own custom, unique voice as a DIY builder. You don’t need a software engineering degree to get a custom tone. You just need a soldering iron, some sockets for testing different values, the right resistors, and a basic understanding of how the frequency bands interact. There is absolutely nothing like the feeling of physically creating your own real tone with your own hands, plugging it into a real amp, and playing that very first chord.
To help show how this works in practice, I have put together an initial resistor lookup matrix based on these 8 iconic artist profiles. Please note that this chart is a tentative. I am sharing it to illustrate the concept and show how easy it will be to create your own custom curves with this information.
September 16, 2026 at 5:34 pm #40552
BarryKeymasterA little more detail on the ROCK-Q:
The idea behind the Artist Profiles is not simply to create different EQ settings, but to shape each profile around the frequency relationships that define a particular player’s sound. The chart below shows the reasoning behind the current profiles and how the individual filter choices were used.
Technical Breakdown of Artist Profiles
The specific filter choices in this matrix serve distinct electrical purposes before your signal hits the clipping stage:
- Tom Scholz: Maxing out the 800 Hz band creates a steep mid-range peak that concentrates the guitar’s energy into a narrow vocal register, while taming the low end keeps his long, singing lead notes from turning into mud.
- Randy Rhoads: Pushing a tight, symmetrical arch focused at 400 Hz and 800 Hz steps up the mid-range response, allowing single-note solo passages to sound full and distinct on a bright, high-gain amplifier stage.
- Michael Schenker: The balanced dome curve over 400 Hz, 800 Hz, and 1.6 kHz closely emulates a physical wah-wah pedal parked halfway open, narrowing the instrument’s bandwidth to focus purely on throat-like solo articulation.
- Tony Iommi: Slicing away sub-bass at 100 Hz replicates the high-pass coupling filters of his modified preamp gear, while a massive 400 Hz boost drives heavy low-mid heft through detuned strings before a treble drop shaves off brittle fizz.
- David Gilmour: An aggressive boost spanning 400 Hz and 800 Hz forcefully fills the mid-range cavity left behind by scooped vintage fuzz pedals, while a sharp roll-off at 3.2 kHz removes the harsh transistor hiss from high-gain sustain.
- Brian May: A steep low-end cut paired with an incremental incline up through 800 Hz, 1.6 kHz, and 3.2 kHz mimics the tone-shaping footprint of an always-on treble booster hitting a small, driven tube output stage.
- Eddie Van Halen: A broad mid-range lift centered at 400 Hz, 800 Hz, and 1.6 kHz serves as a clean pre-amp gain boost, thickening up standard bridge humbuckers and driving a vintage British valve amp into fluid lead saturation.
- Kerry King: A continuous mid-high climb peaking at 800 Hz drives a razor-sharp rhythm attack through high-gain tube preamps, providing the necessary definition for complex, high-speed thrash metal tracking.
- Kirk Hammett: Pushing the extreme lows and highs while slightly dipping the center frequencies creates a classic scooped contour, delivering an aggressive, wide rhythm crunch that stays clean of vocal frequencies.
September 17, 2026 at 10:01 am #40561Byrdhouse Compressor
ParticipantI’d definitely like to read more about what you’re currently developing.
September 17, 2026 at 7:49 pm #40564
BarryKeymasterAnother project I’ve been working on is the NostalgiTone Compression Engine.
Introducing the NostalgiTone Compression Engine
This project has turned out to be a pretty interesting compressor. It uses an LM13700, which you’ll also find in classic compressors like the Dyna Comp, but the way it is used in this circuit is quite different. The overall topology is closer to what you would find in a more studio-oriented compressor, with the signal path and compression control handled differently from the traditional guitar compressor approach.
Solving the “Dark Tone” Dilemma
One of the things I specifically wanted to sort out was the tendency for compression to take some of the top end out of the guitar signal. The Compression Engine retains the compression and sustain without introducing that darker character.
High Sustain, Low Noise Floor
It’s also surprisingly quiet, and there is a great technical reason for that. Unlike vintage compressors that run your guitar signal directly through a noisy control chip, the LM13700 here isn’t the main audio path. Instead, it sits quietly in the feedback loop of a high-quality op-amp, acting as a background controller.
- The Benefit: This keeps the gain-control circuitry out of your direct signal line.
- The Result: A pedal that provides massive compression and sustain without dragging a wall of background hiss along with it.
Active Ratio Control
The Ratio control matches this streamlined efficiency by actively adjusting the intensity of the compression curve itself:
- Lower Settings: Dials back the circuit’s response so your natural transients and picking dynamics pass through unhindered.
- Higher Settings: Transitions seamlessly into a thick, uniform studio squeeze.
The result is a highly musical range that goes from a transparent, “always-on” enhancer to heavy, endless sustain.
Control Interface & Modding Potential
The interface provides direct adjustment over the core compression parameters via three controls: Threshold, Ratio, and Level.
- Preset Timing: The Attack and Release timings are preset via fixed resistor values on the PCB to favor maximum note bloom and natural decay. This profile is tuned specifically to prevent clipping on high-output pickups during sustained solos and to preserve the lower-frequency transients of individually picked chord passages, rather than clamping down too quickly on fast, percussive tracks.
- Easy Customization: For builders who want to customize the envelope characteristics, these timing constants are entirely determined by standard RC networks on the board. You can easily alter the response by swapping the fixed resistor values, or by wiring an external SPDT toggle switch to alternate between two different capacitor values for selectable fast and slow recovery times.
A New Direction
It’s another example of the direction I’m taking with the newer NostalgiTone projects. I’m not trying to make another version of something that already exists. I’m taking some familiar technology, approaching it differently, and trying to turn it into something that has its own purpose.
The Compression Engine is one of the many projects I’m particularly looking forward to getting out there.
September 18, 2026 at 10:49 am #40569
brdModeratorThe Compression Engine sounds very interesting.
I like to use an early and late stage compressor in my rig. I have an old build of a Dyna Comp style circuit with the original CA3080 chip that I have used for my late chain comp. The LM13700 is a working equivalent of the old CA3080 so there is some familiar ground here. I love the Dyna Comp pedal but it adds some noise that is noticeable, and to me It is not really a “transparent” compressor. Also having mod options, is always a plus for me. I’m looking forward to trying this.
