Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › Show Off Your Build › Plexi Plus-Plus
- This topic has 10 replies, 6 voices, and was last updated 8 years, 1 month ago by
August 5, 2018 at 4:31 pm #1527
InactiveHere is a recently finished build I’m calling the Plexi Plus-Plus. It is a Plexi Plus and Dr. Rock in series. I’m able to cover a great deal of classic Marshall territory here and the two circuits stack well together when I have the PP set for lower to moderate gain and the DR also set for low gain. I can also set the PP for some nice rhythm grind and then switch over to the DR for higher gain leads. Beautiful sea foam green enclosure and color coded pointer knobs courtesy of Mammoth.
August 5, 2018 at 4:58 pm #1528Anonymous
GuestSweet! Nicely done all around.
August 6, 2018 at 3:17 pm #1542Anonymous
InactiveNice build.
-S
August 6, 2018 at 5:17 pm #1545
CybercowParticipantWell done. Good looking build.
August 7, 2018 at 4:33 pm #1555
BarryKeymasterSorry I missed this one. Very awesome combo and thanks for the report and share!
I love to here all about exciting new combo ideas. The guitarist painters palette = Combo’s!
August 7, 2018 at 5:38 pm #1556Anonymous
InactiveThanks guys. I’d definitely give this a try if you are looking for a good range of Marshall tones without a bunch of extra knobs and switches. The DR basically picks up where the PP leaves off so you have light gain up to higher gain Plexi tones and everything in between.
September 20, 2018 at 4:58 pm #2106Anonymous
InactiveThis is very interesting to me. I think you did a great job and chose two stellar circuits. My build document shows a jumper on the bottom two lugs of the stompswitch rather than the resistor though, so I’m wondering if this is the reasoning behind my Dr. Rock having issues. Which value resistor did you go with?
September 20, 2018 at 5:20 pm #2108Anonymous
InactiveHi BillTex79. Those are just 0 ohm “jumper” resistors. Same as bare wire. Just a little easier to work with.
September 20, 2018 at 6:54 pm #2114
BarryKeymaster@ BillTex: Yes the single stripe (not other stripes or colors) indicates a 0 ohm resistor. I have a couple but do not use them as I always use wiring boards for the multiple 9v and ground pads eliminating a lot of extra long wiring. If you have an issue you need to post a proper troubleshoot thread.
October 3, 2018 at 4:44 am #2313Anonymous
InactiveThank you both for replying to me. I wanted to exhaust all options before posting a thread, and today I found the bad connection and got the Dr Rock up and running. I’m impressed with this circuit!! I’m thinking about trying a Plexi Plus like the one above with two Tweq’d eq circuits; one pre, and one post. Does anyone have any thoughts on this idea?
October 3, 2018 at 11:41 am #2317
BarryKeymasterMany people use Pre and Post EQ for different reasons. Let us know what you think if you decide to go ahead.
While the demo below uses a graphic EQ you will benefit equally by watching it. You will also notice that the Jester itself has a Tone TwEQ control built in. Keep that in mind when the demo the Graphic EQ pre and post.
I hope that helps you decide.
