Hi guys,
long time lurker here, however my very first post:
I recently built the excellent Paramix and absolutely love it! Right now I am thinking of a stereo amp setup and using the Paramix for the routing. But as I understand the Paramix can only be used to switch each amp on/off via the “Kill”- and Bypass-Switch and not to switch between them or to have a dedicated “Both”-switch, am I correct here?
If so, do you have any idea how to configure the Paramix to allow A/B/Y operability?
<hr />
Also, in order to avoid a potential grounding loop between the two amps, I plan to implement two isolation transformers into the build, following R.G. Keen´s layout (http://www.geofex.com/FX_images/TransformerSplitter.pdf). However, I am wondering if it makes sense to implement them in the Paramix or rather to put them in a separate box at the end of my signal chain to avoid any ground loop between my effects chain and the two amps.
Signal flow would look like this:
I- – – – – > FX Chain 1 -> Amp 1
Paramix
I – – – – -> FX Chain 2 -> Amp 2
Sorry if these are noobish questions but I really couldn´t get my head around it.
I hope you had some nice Christmas Days! 🙂
Best
L.D.
