Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Muff OpAmp Mod (answered)
- This topic has 3 replies, 3 voices, and was last updated 7 years, 8 months ago by
February 22, 2019 at 5:11 pm #4418
InactiveHi!
I’m starting work on my 3rd pedal project, but first one from GuitarPcb. The other two were kits, so there were pretty straight forward. Now I need more of a challenge. I’ve ordered the Muff OpAmp pcb and I like to add the Tone Bypass and Diode switching. I have a couple of question though
Tone Bypass – can I use the DPDT board? If so, how do I populate the board and connect it to the Tone and Volume?
Diode Switching – If I use the DPDT board, how do I get 6 diodes to each side? I want to use the 1N914 for the BOM on one side and try 1N34A on the other. I am planning on using sockets on the 1N34A, since it is an experiment. I just don’t know how properly place the 6 diodes on each side.
Link to build doc: https://guitarpcb.com/wp-content/uploads/2018/06/BD_BMP-OP-AMP-v2.pdf
Thank you
-N
February 22, 2019 at 7:06 pm #4422Anonymous
GuestRTFM. There is a diagram in the Build Doc that shows how to wire the TONMANN tone bypass. There is also an instruction for wiring a Tone TwEQ in place of the stock tone stack.
If you want to string 6 diodes onto one side of a DPDT, you will need to solder three together facing one direction and stack the 2 ends onto the DPDT next to another three facing the other direction. Obviously, the middle diode in each string is not touching the board.
When adding diodes in a string, you will increase the Forward Voltage, Fv, which will increase the signal level that the string passes. Since 1N34A are germanium that pass a lower Fv than the 1N914, you may wish to use 6 on the 1N34A side and only 4 on the 1N914 side of the DPDT. This will result in a closer signal level between the 2 positions of the switch.
February 22, 2019 at 10:06 pm #4423
BarryKeymasterSince you are new, new I would state that RTFM is what we lovingly refer to as Read The Fantastic Manuals. The main build document aside you can also learn a ton from our RTFM pages also known as the Guides Pages which I am certain you will find helpful.
You will even see a diagram showing how to wire a DPDT board with examples but also check out all the PDF Guides up top as well.
February 26, 2019 at 11:33 am #4456Anonymous
InactiveThanks for the answers.
-N
