Viewing 4 posts - 18 through 21 (of 21 total)
  • #5894
    Guest
    OK.  I hope you had a nice night’s sleep.
    First,  I suggest you remove the ICs and power from the circuit.  Then, do a complete re-solder of all connections and joints.  Replace the ICs and power and retest.  If no output, then use your audio probe and trace the signal through the input jack > bypass switch > board IN “T” pad > IC1B pin 7.> IC1A pin 1 > OUT pad “T” > bypass switch > OUT jack.  I saw on your video that the LED was flashing, so I believe the LFO circuit is fine.  Report results.
    #5896
    Guest
    Wilkie1: OK. I hope you had a nice night’s sleep.
    Héhé, it’s yours now, thanks to you too.
    Wilkie1: First, I suggest you remove the ICs and power from the circuit. Then, do a complete re-solder of all connections and joints. Replace the ICs and power and retest.
    I tried when i woke up with a coffee mug and… you was right with Octo-Coupler, and I have broken the track from the octo-coupler to R17. I made a soldier link with cable inside like in the photo downside 😛
    And if you look the last video, you will see the result! https://youtu.be/GfjNqzXYMbo
    Barry: Finally we cannot guarantee an xvive opto couplet will match the specs of the NSL-32
    It worked for me 🙂 the octo-coupler were just reversed.
    I’ll pay more attention to the smooth button later (or maybe it’s normal?),
    I’ve to go to work thank you all, I’m learning a lot with your help 😉
    #5900
    Guest
    Bravo!  I am happy to hear that you solved the problem.  We look forward to seeing your finished project on our forum.
    #5903
    Guest
    Wilkie1: Bravo! I am happy to hear that you solved the problem. We look forward to seeing your finished project on our forum.
    Thank you, i’ll do it. Before I’m searching how to engrave indications on the pedal. I’ve a dremel but i’m not expert with it 🙂
    See you!
