Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › After Blaster R4 (answered)
- This topic has 7 replies, 2 voices, and was last updated 7 years, 8 months ago by
February 3, 2019 at 7:55 pm #4083
InactiveI’m adding the After Blaster to a build, and I would like to use the 2N5457 for added grit. In the build doc, it states that R4 will need adjustment for this. If using a J113, it has 2k4 as a starting point for R4. I’m wondering if I should go up from that R4 value for the 2N5457 and if so, what is a good starting point? I’m wiring the Red special with a Tone TwEQ and the After Blaster in a 125-B, and R4 is mounted on the underside of the foot switch. With so many wires and connections, I’m just trying to minimize the times I need to flip the foot switch over and replace that resistor.
February 3, 2019 at 10:45 pm #4084Anonymous
InactiveIn hindsight, of course, I should have probably mounted the sockets for R4, R1 and Q1 facing up on the PCB with the switch mounted.
February 3, 2019 at 11:03 pm #4085
BillyModeratorYou can bias your fet prior to connecting the after blaster to the other circuits
Simply connect your dc jack power and ground to it then change your resistor till you get 5v on your drain
I used a J201 with 20K to get 5v on the drain so I’d say start at around 10K
February 3, 2019 at 11:47 pm #4086Anonymous
InactiveHey thanks Billy. That really helps me out.
February 4, 2019 at 12:13 am #4087
BillyModeratorYou can also bridge the after blaster I and O pads to have a listen to it once it’s biased
I used a breadboard jumper wire for a nice solderless connection, if you don’t have any a bit of solid core should do the job no problem
February 4, 2019 at 12:40 am #4088Anonymous
InactiveSo, bridging the I and O pads and connecting the input/output jacks, it will basically act as “stand alone”?
February 4, 2019 at 2:00 am #4089
BillyModeratorMore or less
If you look at the schematic you can see
Looking at it your IN jack tip goes to I (input of main circuit) through the circuit to O (output of main circuit) then to the DIP or DPDT switch where you can switch to either position 1 after blaster active or position 2 bypassed / off , so you could theoretically use it as a stand alone by jumpering I and O and doing away with the DIP switches
I like the idea of it as an add on to liven up an anaemic circuit and being able to boost it add more gain etc as required
February 4, 2019 at 9:24 am #4090Anonymous
InactiveGot it. I like the idea of being able to sound test it before running it to the other circuits. Thanks for the input Billy.
