Purchasing Link: https://guitarpcb.com/product/nostalgitone-metal-godz/
The NostalgiTone Metal Godz Dual Combo is designed to accommodate a full spectrum of Bass tones, even drop tuning is faithfully represented. Embrace the power, and unleash the fury with the Metal Godz Dual Combo.
Combining both circuits unleashes an unparalleled array of tones, unmatched by any other combination. Included is the secret used by Metal pioneers, evident the moment you hear it. Equipped with the Rangemaster-style Boost, you have complete control over your tone, whether you want to go full Doom mode or cut through the mix.
Finally, with built-in order switching, it’s like having an entirely different pedal at the flip of a switch. Simply point the toggle at the effect you want to come first.
(Use a 3PDT On/On short shaft / stubby switch)
Order switching is built-in, with pin header connections making wiring a breeze.
Customer Build: Click on the image to go to the Build Report.
Be sure to check out my other NostalgiTone products.
