Purchasing Link: https://guitarpcb.com/product/nostalgitone-zoso-tone/
The NostalgiTone ZOSO Tone Dual Combo is the perfect combination of Amp and Fuzz tones. With added order switching it provides endless sonic possibilities for exploration. Unleash the tones that defined a musical era!
A powerful fusion of two iconic circuits designed to recreate the legendary sound of Led Zeppelin. The “WattAMP” circuit delivers robust, high-headroom clarity reminiscent of Hiwatt amps, providing rich overdrive tones without excessive volume. Meanwhile, the “Luna Fuzz” offers a thick, substantial fuzz tone, allowing you to explore a wide range from tight overdrive to ultra-saturated fuzz. Experience the unmistakable tones that defined an era and unlock endless sonic possibilities!
Key Features:
- Authentic HiWatt-style preamp and tone stack with adjustable EQ for precise tonal control.
- Fuzz is used for soaring solos and powerful riffs, equally effective as a standalone Fuzz tone or in tandem with the Preamp.
- Built-in order switching for endless tonal possibilities, allowing you to easily reverse the signal path.
(Use a 3PDT On/On short shaft / stubby switch for order switching)
ZOSO Tone Build Document
Customer Build Review: Click the image to go directly to the review.
Be sure to check out my other NostalgiTone products.
That ZOSO build is badass and then some. Well done!
