Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › Spring reverb driver
- This topic has 5 replies, 3 voices, and was last updated 4 years, 9 months ago by
mybud.
October 14, 2021 at 8:58 am #21170
mybudModeratorGreetings collective wisdom: I tried recently to mod an old rare board (now discontinued) designed to drive a spring reverb unit. Unfortunately I lifted some tracks in the process and haven’t managed to get it back to life.
My question is whether an existing GuitarPCB circuit might be usable to get signal in and out of the spring reverb directly, that is, some kind of preamp or the Paramix, what have you. Any advice gratefully received. More info on the spring reverb specs follows:
- Input Impedance 8 Ohms, Output Impedance 2250 Ohms
- Input Insulated/Output Grounded
I figure that the low input impedance might be a problem, since most of the guitar circuits I’m familiar with call for a very high input impedance on the order of 1m or more to avoid loading down the circuit, I assume. As before, any advice gratefully received. Best to all, mybud
October 14, 2021 at 10:22 am #21172Anonymous
GuestMaybe not helpful, but I recall there being a Craig Anderton schematic for something like this. I think I might even have a stripboard layout someone did for it. I swapped out a reverb tank in an amp and had grandiose plans to use the old one in stand alone configuration. I had not thought about it for a while but I can see if I can dig up that vero layout, schematic and any information I may have…
October 14, 2021 at 11:07 am #21173Anonymous
GuestI couldn’t find any documents in my collection for it but a little research on the internet and what I had been looking at was the Anderton Stage Center Reverb. Lots of info out there on it including some vero layouts and it seems some boards were available for it from other sources at some point. I don’t know if it is compatible with your tank but it does list several Mod reverbs that it does work with so you might be able to compare specs…
October 14, 2021 at 1:05 pm #21177
mybudModeratorThanks Brooks, I will check these options out. Appreciated. Best, mybud
October 14, 2021 at 1:07 pm #21178
Big OParticipantI did a little research on this and not really sure how to do this, but read in a thread discussing how to hook up reverb tanks that you will likely need a pre-amp and amplifier. It was suggested that you may need a low impedance amp at the input and something with pretty high gain on the output. A jury rig setup would be something like trying a headphone amp feeding the input and a mic amp on the output. I know there are headphone amp kits and on the internet and Parts Express has a mono amp kit that might work. But that is the extent of my very limited knowledge on the subject .
October 14, 2021 at 1:20 pm #21179
mybudModeratorThanks, Big O. Appreciate your feedback. Best, mybud
