Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › PURP has no sound when turned on.
- This topic has 17 replies, 4 voices, and was last updated 3 years, 1 month ago by
September 10, 2023 at 9:33 pm #29765
GuestI’m new to building. Just did a pumped up rangemaster kit. Bypass works. LED turns on when engaged but pedal has no sound when turned on. I get voltage to and from the board and switch. I was wondering if someone could help.
September 11, 2023 at 12:38 pm #29775
BillyModeratorAlthough its fairly difficult to see it looks like your diode D1 is the wrong way around the cathode striped side should go the other way around
Easy enough to confirm check what voltage you get on pin 8 of IC1 I’d suspect little to nothing
What may be happening is with the diode the wrong way around power will conduct through it straight to ground rather than into the circuit via IC1
September 11, 2023 at 3:32 pm #29778
BarryKeymasterD1 is in the correct orientation for v4 of the board.
I am looking hard at some of the solder pads that seem open. You may want to reflow your solder joints.
For example:
Also remove the wire from the inside of the Jack so your plug is not going to hit it when inserted.
Also two different Red Wires may be damaged depending on how many strands?
September 11, 2023 at 4:12 pm #29781Anonymous
Guest- How are the pins numbered? Also I put the gray line of the diode on the white striped side of the PCB if that helps you. I can take a better picture. How much voltage should I get and where am I measuring across? Is that from the pin to the ground or just to the other side of the diode?
September 11, 2023 at 4:21 pm #29782Anonymous
GuestIn response to Barry I tried improving the solder but I ended up making it so the led won’t even turn on anymore. Should I just get a new PCB and GPCB and redo the solder joints? I have reworked this thing so many times from taking it apart trying to locate the issue. It was soldered much better initially but now some of the wire holes are burnt and several of the wires have been nicked with the iron as you pointed out. I also have a problem of the wires fraying where they attach to the board and then breaking after reworking another part. Is that from too much heat?
September 11, 2023 at 5:20 pm #29784
BarryKeymasterSince it is likely damage after what you just said I absolutely believe the project is worth getting a new PCB and 3PDT to finish it.
September 11, 2023 at 6:13 pm #29785
BillyModeratorDamn I checked the guides page for the latest build doc too
Guess I’ll stick to the shop docs from now on
Twice in a week
I’ll give myself a slap
September 11, 2023 at 6:28 pm #29787Anonymous
GuestAfter dissembling the pedal but not the PCB it appears the damage is in the switch. Is there a way I could wire this as always on to test the pedal circuit but skip the switches? If so which wires are needed to connect to the main PCB?
September 11, 2023 at 6:29 pm #29788Anonymous
GuestI would like to skip the 3pdt and the my spdt
September 11, 2023 at 6:33 pm #29789Anonymous
GuestIn my mind I would connect the audio tip to the T in and the ring to the G in. Then the same for the out. Wire 9 volt as it was, but I’m not sure about the spdt because I don’t understand what it’s doing.
September 12, 2023 at 6:21 am #29793
BillyModeratorThat’s correct just wire your in and out jacks to the pcb
The spdt just puts either C2 or 3 in paralell with the input cap C1 giving you full mid and treble range
Leave that in the middle off position
September 12, 2023 at 4:17 pm #29799Anonymous
GuestIf I leave the spdt unwired for testing is that off? Or will that break the circuit?
September 12, 2023 at 4:55 pm #29800
BillyModeratorYes you can leave it out it’ll just go through C1 looking at the schematic
September 12, 2023 at 11:54 pm #29806Anonymous
GuestWell I’ve tried to isolate the board and I can’t get anything but buzz. I have voltage across the wires. The resistors are all measuring what they should. I have varied resistance as expected across the pot. I just can’t get it to work. i cleaned the board and checked solder joints too.
September 12, 2023 at 11:55 pm #29807Anonymous
GuestSeptember 12, 2023 at 11:56 pm #29808Anonymous
September 13, 2023 at 12:24 am #29811
BarryKeymasterThis would help you identify the issue by location quickly as well as being a valuable tool for future projects.
