Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › NostalgiTone Vibe – LFO Trouble shooting help
- This topic has 5 replies, 3 voices, and was last updated 1 year, 10 months ago by
January 10, 2025 at 9:39 pm #34751
GuestI’m building a NostalgiTone Vibe. I’m now testing it before boxing it.
- Sound works
- Volume works
- Voice works
- RATE does NOT work
- INT does NOT work
- LED is on and brightens and dims with the Trim pot, as well as the Voice pot.
- LED does NOT oscillate
- I’m guessing its an issue in the LFO section, but I have no idea what I should be troubleshooting.
- I’ve checked resistors and caps, is there anything obvious that I am missing?
- 100p & 470p are Film Caps, not ceramic Caps, does that matter?
Any tips or clues would be appreciated
January 11, 2025 at 1:11 am #34753
mybudModeratorTry covering the LED/LDR section with a dark cloth to eliminate ambient light for starters. Testing the pedal in normal daylight conditions won’t allow the LDRs to do their magic thing. Let us know if that changes things.
January 11, 2025 at 3:02 pm #34761
BarryKeymasterDoes the LED pulse?
I would personally re-flow your solder joints by reheating the solder pad and then have a little extra solder handy to touch to the pad.
For example your Rate and Intensity joints do not look very filled in.
If that doesn’t help I would re-flow the entire project.
If that doesn’t help provide voltages for the ICs.
January 12, 2025 at 7:40 pm #34770Anonymous
GuestThanks guys, I will go through and do all as suggested.
Yes, I haven’t soldered those pots in yet.. I tested the first ones and they seemed to be off and replaced them, The rate B100K post was only measuring 60K. it was a paint to remove, so I wanted to test it without soldering it… could be a reason its not working now ?
January 13, 2025 at 1:13 pm #34779
BarryKeymasterYou cannot accurately test values in circuit. Some may be correct but many will be affected by other components in the path.
You absolutely must solder components for the circuit to work correctly.
January 13, 2025 at 8:33 pm #34783Anonymous
Guestgot it.
soldered, same issue, LED on, not oscillating.
Pulling the IC socket out, and redoing, I don’t think it was compressed enough into the PCB board.
will let you know, thanks for the advice
