Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Muff Pi (solved)
- This topic has 9 replies, 4 voices, and was last updated 6 years, 2 months ago by
July 31, 2020 at 5:59 am #13853
InactiveHi gurus,
so glad I found this site! I have some basic electronic skills and have built several kits (solid state amps and Valve amps) I just built a Muff Pi green russian with a few of the mods and when I bench tested it it worked ok but soon as i mount it into the enclosure PSU read 0V so i figure dead short somewhere. so I remove all PCB’s and switches and the short happens when I connect the output jack. I know it looks a bit ugly but Im sure someone can guide me!
Thanks in advance!!!
July 31, 2020 at 7:18 am #13854
BillyModeratorDifficult to see Stu but you may have connected your output jack ground to the ring connection
If you put a jack in like the image below and trace the connections round to thier solder lugs
The ground lug connects directly to the sleeve like this
Your IN jack which I can see is correct, just an FYI if you’re not using a battery you can use mono jacks for both in and out I notice you have stereo for both which are slightly more expensive and welcome to the forum
July 31, 2020 at 1:23 pm #13859Anonymous
GuestDo I also see that the input jack ground wire is soldered to the +9V pad on the new V5 3PDT wiring board?
July 31, 2020 at 3:11 pm #13861
BillyModeratorGood spot sir I was looking at that as well thinking could do with a clean up never even noticed the +9v written all over it
I think you’ve reclaimed the ol’ eagle eyes title
July 31, 2020 at 5:59 pm #13862Anonymous
InactiveThanks for reponse, we will have this nutted out in no time!
This is the wiring diagram I followed, I though it odd that the 9V wired to sleeve
July 31, 2020 at 7:09 pm #13863
BarryKeymasterThat is an old wiring board. We have upgraded the wiring boards to have symmetrical pairs of 9v / Ground connections placed on either side of the boards as opposed to just way too many grounds. I am still going through the old build documents and updating those that happen to have that particular diagram first.
July 31, 2020 at 7:21 pm #13864Anonymous
InactiveThat was it! I must have a newer revision board, you guys are every impressive!
Here it is, had to solder LED to off position due to butchering the solder pad for on oops. MKII will always be better!!
July 31, 2020 at 8:56 pm #13866
BillyModeratorI’m glad I’m not the only one that missed that +9v silkscreen Stu!
Joking aside you can jumper your LED with a wire to have it on when in effects mode just desolder that leg and solder a jumper wire like this from the leg to the 3PDT lug obviously be careful you don’t damage the LED with too much heat
July 31, 2020 at 9:44 pm #13868Anonymous
InactiveI wonder how it worked when I bench tested it? Next build i’ll use a switch with LED, the bezel im using I can’t remove the LED so need to desolder each time I pull the switch out, hopefully I don’t have to do that too many more times
Thanks for all your help
Stu
July 31, 2020 at 10:51 pm #13869
BarryKeymaster -
