Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › Very first builds
- This topic has 15 replies, 7 voices, and was last updated 6 years, 5 months ago by
mybud.
May 1, 2020 at 5:39 pm #12706
InactiveHello folks,
I’m new to the forum and also new to diy guitar pedals. Actually I’m a complete newbie when it comes to electrical engineering. Tomorrow I’ll get my first two kits from Musikding: the Easy Fuzz kit and Acapulco kit. I’m starting with the fuzz kit as it seems to be the most straight forward one.
Stoked to start this new hobby as I have been playing guitar for 24 years by now and a recording and mixing engineer for about 10.
Fingers crossed that these first builds will be okay. Thanks for having me here. Cheers!
May 1, 2020 at 6:15 pm #12707Anonymous
InactiveI’m excited for you. Fuzz is a good starter. Have fun.
May 2, 2020 at 4:44 am #12711
BillyModeratorWelcome Tom
Take your time and enjoy creating your first effect you’ll wonder why you didn’t do it sooner!
You’ve come to the best forum out there so no matter if it fires up first time or not we’ll be happy to help
Make sure you read the guides page to get yourself off to a good start
Good luck with first your builds
May 2, 2020 at 5:50 am #12712Anonymous
InactiveThank you both!
May 2, 2020 at 8:05 am #12713
mybudModeratorWelcome Tom and enjoy the build. Have a look at the soldering guide meanwhile, in addition to the resources Billy mentioned, and there’s quite a bit of info on the circuit available on the web. Best of luck.
May 2, 2020 at 3:12 pm #12715Anonymous
InactiveThanks!
I’ve been studying some of the guides and pdf’s here. Very informative! Great to have that.
My goal is to build the sunn-T when I have more experience. Unfortunately the kit isn’t in stock right now at Musikding (I live in Holland).
I’ll start with the Easy Fuzz tomorrow. 🙂
May 2, 2020 at 4:02 pm #12716
Big OParticipantWelcome to the addicting hobby of building pedals! I started out with one of the easiest circuits to build, a fuzz face, because at the time the only manufactured FF’s with Ge transistors were quite expensive. So after having had only a single episode of replacing and rewiring pickups on a guitar as my electronics and soldering experience, I dove into pedal building head first. Don’t get discouraged, if you encounter any problems at first, there are plenty of people to help you on your way. My first pedal didn’t work right away, which prompted me to buy my first multimeter, although that didn’t help. Substituting low gain silicon transistors into the circuit solved the problem, suggested by someone on the build forum – I had a bad Ge transistor in the kit, but the vendor sent me a second pair free. Of course I later used the original good one to build a second Ge-Si fuzz face once I got more adept at pedal building. I still feel I am bit of a novice after more than 20 builds, including some circuits I have designed myself by modifying known schematics. I think the best advice I can give is start simple and work your way up to a complex build (my most complex so far has been a tube amp). You don’t have to do 20 pedals before moving on to complex builds, but maybe do a couple simple circuits first, the moderately difficult, and then on to the complex.
May 3, 2020 at 1:07 am #12721
mybudModeratorThree suggestions that might be helpful, which you might already have gathered from the various guides: Socket your transistors as a basic principle. Apart from the fact that they don’t like excessive heat and shouldn’t strictly speaking be soldered straight to the PCB, socketing means you can swap them out for others as needed without harm.
Second, try to leave some slack in your off board wiring (pots, jacks, and so on). Have a look at Cybercow’s post regarding the Apollo tremolo (Shiver quiver, he calls it) which has a pictorial guide to how he does it. That extra couple of centimeters in the off board wiring makes troubleshooting or mods just much easier and doesn’t strain them or the PCB unnecessarily.
Try to get hold of a temperature-controlled soldering station. Ok, they cost a bit more but it’s worth the expense if you’re going to build more than one pedal, which I’m pretty sure you will 😉 The cheaper options don’t maintain a constant temperature, which can make one’s soldering less than reliable. A friend of mine advised me to do this when I started out (three or so years ago) and I’m very glad I did.
There’s a great sense of achievement when the build works, not to mention adding something new to your musical palette.
The Sunn-T is a classic and great circuit. You might be able to get it direct from Barry in due course. Again, very best of luck and keen to know how it goes.
May 3, 2020 at 8:30 am #12724Anonymous
InactiveThank you for the tips!
I got a this soldering iron, Basetech ZD-99. It was pretty cheap but at least it’s temperature controlled.
I’ll post updates here soon. 🙂
May 3, 2020 at 9:58 am #12726Anonymous
InactiveOk first 2 questions after going through the guides:
1. It’s obvious most parts have + and – so they need to go into the PCB a certain way. That’s clear. But AFAIK this doesn’t go for any of the resistors? They can be placed either way?
2. I believe I’ll need a multimeter as well to check and troubleshoot voltages. Can I use this for the minitrimmers as well that might need to be set to a certain KOhm?
Thank you 🙂
May 3, 2020 at 10:45 am #12727
mybudModeratorOk, resistors aren’t polarised, but it helps for troubleshooting to line up the tolerance bands similarly (gold or brown). If you follow the principle of building shortest to tallest, start with resistors, followed by diodes (which are, match the stripe according to the PCB), then sockets, caps and elcaps last. These are polarised too, so match the positive side to the plus sign, which implies that the negative stripe will appear on the other side. You can often bias a circuit by ear, so hold off on the multimeter for now unless you absolutely have to have one. That said, they are useful gadgets, especially if you get one with capacitance, continuity, and diode measurements. Hope this helps meanwhile. Best
May 3, 2020 at 2:59 pm #12729Anonymous
InactiveThat’s awesome 🙂 thanks for the help.
May 3, 2020 at 4:21 pm #12730Anonymous
InactiveI’m also about to start my first build here as well, one of the EA trems, and have found all the information here SUPER helpful along side with Fuzzlord and DIY Guitar Pedals (very apt name) on YouTube. I haven’t started the build yet because I’m super nervous of messing something up (it was a gift) but I gotta jump in and some point and in the 3 days I’ve spent reading and watching videos I feel more than equipped to try it out!
Good luck on your build! Your post has given me a burst of confidence, so I think I’m gonna be starting pretty soon 🙂
May 3, 2020 at 4:31 pm #12731Anonymous
GuestAlong with the other great posts welcoming you to this forum, I would like to add this advice:
RTFM!
That means “Read the FABULOUS manuals!” The guides on this forum contain a wealth of great information that will apply to ALL of your builds. So, read, read, read before you start building. Welcome!
May 4, 2020 at 2:16 am #12734Anonymous
InactiveThanks folks. You too Marcus!
I’ve been around long enough that I indeed first do as much research as I can and actually RTFM. 😀
May 4, 2020 at 2:29 pm #12742
mybudModeratorHI Marcus and welcome. The EA is a very nice sounding tremolo and an enjoyable build. Go for it.
