Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Point to Point Tone tweq support (solved)
- This topic has 9 replies, 3 voices, and was last updated 3 years, 2 months ago by
Billy.
August 26, 2023 at 1:17 pm #29584
Guest-
- <li style=”text-align: right;”>
- I’m not sure if I’ll find the help I’m looking for here but I figure it’s worth a try. I have built a point to point modified muffin with tone tweq eq. I included the clipping mods, hpf, lpf, tone bypass and tone tweq and everything wirks great other than the tone tweq. When I switch off the bypass mode the only effect I get from the eq circuit is a volume drop from pin 2>1 of the tl072 corresponding with the 300k feedback resistor. When audio probing I get no change in tone anywhere within the circuit and the pots make no change. I have traced all my connections visually about a million times and gone over the schematic just as many times. I’m at a total loss and would love any advice you can give. Thanks guys
August 26, 2023 at 1:20 pm #29585Anonymous
Not sure why I shrunk those pics. These are biggerAugust 26, 2023 at 1:22 pm #29586Anonymous
August 26, 2023 at 10:58 pm #29590Anonymous
GuestI can imagine the many hours you have already spent on this. Without a GPCB board to examine, I can only make these suggestions:
Use the schematic to verify every connection. Measure the power at every pin on the TL072 Use an audio probe to trace the signal into the TL072 and through each section of the opamp.
This was truly an ambitious endeavor. I hope you can see it through to success.
August 27, 2023 at 8:56 am #29594Anonymous
GuestThank you Wilkie. I’m getting 4.31 at pin 3 and 5 where the voltage divider comes in but I got .001 or something like that everywhere else. I’ve already replaced the chip once because I thought maybe I’d burned it. I have successfully used op amps with point to point in the past with no trouble as well as tons of transistors. What voltage should I be expecting?
By the way, pins 4 and 8 are clipped as the schematic shows no contact there.
Thanks again for any feedback that may help me get to the bottom of this.
August 27, 2023 at 12:40 pm #29596Anonymous
GuestI finally figured out my mistake. The op amp in the schematic doesn’t show pins 4 and 8 so I omitted them. I finally looked back at the power section and saw those numbers to +/- there. Eureka. Thank you.
August 27, 2023 at 2:33 pm #29598
BillyModeratorAs you’ll know Ollie
You definitely need pins 4 and 8 for power and ground
Just for future reference as you saw IC pins are usually shown in the power section of the schematic where you’ll see a small V- 4 and V+ 8 indicating dual op amp power pins obviously a small 4 and 7 and 4 and 11 for single and quad op amps
August 27, 2023 at 2:44 pm #29599Anonymous
GuestDefinitely a silly thing to miss but now it won’t happen again. I’ve only recently started learning about the inner workings of op amps. The journey continues.
August 27, 2023 at 8:22 pm #29604Anonymous
GuestDid you miss the fact that Barry has the ToneTwEQ board on sale for only $1.85? That might have saved you a bunch of time adding it to your Muffn.
You must have the patience of Job. Happy to hear you worked it out! Great work!
August 28, 2023 at 9:44 pm #29613
BillyModeratorI’ve seen a few of your builds over on reddit
I’m liking your relic’d enclosure work lately
I’m u/mcknib on there
