  • #37596
    Dave Davies
    I’ve had this PCB around for a while and I’m finally going to build it up. I’m going to use a Two Knob Job board to set up two speed options. As the speed pot will no longer be attached to the main PCB, does anyone have any suggestions on how to mount the PCB in the case?
    Also, I’m wondering just what is SW1 used for?
    #37602
    SW1 switches between 2 stage and 4 stage but not suggested for the Vibe.
    From the Guides Page here is the Combo Build section that shows solutions from many who built without on-board potentiometers.
    Combo Build Guide courtesy of Playsforfun and a Combo Build Thread with examples!
    In short the wire itself can hold the build in place or you can add double-sided Gel tape in a strategic location. It doesn’t take much.
    #37635
    Dave Davies
    Thanks for the reply. I’m going to use the double sided gel tape.
    The PCB has ground connections next to the input and output. Is it better to wire these to the jack sockets rather than relying on ground return through the case metal?
    Thanks, Dave.
    #37637
    The wiring diagram in the build document shows the preferred method.
    #37782
    Dave Davies
    What purpose does TR1 serve? I don’t see anything in the build document to explain it’s setting.
    Thanks, Dave.
    #37785
    Since these type of transistors have a wide tolerance you can Adjust TR1 trimmer till you hear the best phasing typically around 12:00 – 1:00
