Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › switching order (answered)
- This topic has 9 replies, 3 voices, and was last updated 7 years, 6 months ago by
May 4, 2019 at 1:52 pm #5581
InactiveTrying to figure this out with no luck, I’d like to switch 3 pcbs 1-2-3 to 3-2-1 so I just want to switch the 1st and 3rd boards leaving the middle board as the middle, can I do this with a 4pdt or do I need to go to a 6, my brains not working well today any ideas or solutions
Thanks!!
May 4, 2019 at 8:11 pm #5587Anonymous
GuestIf you use a 8PDT switch to change all positions at once, this will work.
May 4, 2019 at 9:44 pm #5590Anonymous
InactiveThanks, I’ll give it a try
May 5, 2019 at 7:34 am #5609Anonymous
InactiveI was trying to figure out a way to use a 4pdt that would leave #2 as a passthrough while switching the 1-3 around it, but all it did was give me a headache, 8pdt makes sense it’s just alot of switch! I appreciate you taking the time!
May 5, 2019 at 1:00 pm #5615Anonymous
GuestYou are welcome. I enjoyed the mental challenge of this. I wonder if anyone else on the forum can come up with a simpler solution?
May 5, 2019 at 9:34 pm #5633
CybercowParticipantWilkie – I saw this post shortly after you posted the drawing you did, and I have to confess, I first thought it was a simple as just extending the 2-circuit switching order concept. But when I looked closer at your response and drawing, my brain started to hurt. Now I need to sit down with a cuppa in the morning and better analyze it and get out my own paper & pencil to actually wrap my head around it. At the moment, I cannot conceive a simpler purely mechanical method. I was initially thinking of a combo of order switching PCBs with 4PDT switches to achieve an “any order” configuration. But I see now that the OP simply wants only to switch circuits #1 & #3. (If I read that correctly.)
moo
May 5, 2019 at 10:29 pm #5635Anonymous
GuestIt took me a few hours and several cups before I was able to come up with the diagram. I kept thinking there must be a simpler way to do this, but he wants the entire chain of three to be reversed. An interesting problem.
May 9, 2019 at 6:42 pm #5658Anonymous
Inactivegot the switch and it’s not going to work, there is no way to mount it in the pedal except maybe glue/pray so I’m going to try and find something, it may end up being a double toggle
May 9, 2019 at 7:25 pm #5659Anonymous
GuestBummer. I thought it would fit mounted through the side of the pedal.
May 10, 2019 at 6:10 am #5667Anonymous
InactiveYeah the image was pretty deceiving the round section all moves and holds the spring, other than maybe internally the only way to mount it would be a square hole with a retainer clip but the spacing is smaller than the thickness of a pedal housing
