Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Superlead OD
- This topic has 18 replies, 3 voices, and was last updated 7 years, 1 month ago by
September 29, 2019 at 9:02 pm #6952
InactiveOk I’m stumped. I built the Superlead OD and I’m getting no sound. Bypass is working fine but the D5 is not working. It seems like I’m not getting any voltage to the board.
September 29, 2019 at 9:43 pm #6953
CybercowParticipantHi Jack – you may or may not have noticed the posts about how to use the forum. Those are important. How can we begin to assist you without the following form you?
- Good, clear photos (Preferably Both Sides of the Board + Gut Shots)
- Voltage Readings of the power supply on the PCB, transistors and ICs.
- A Detailed Description of the Issue(s) You’re Facing
These can help us to understand the problem and find a solution pronto! Please be specific with what’s happening or not happening. Without the info listed above, we cannot provide any meaningful assistance.
September 29, 2019 at 9:45 pm #6954Anonymous
GuestDo you have an LED that is lighting up in either foot switch position? If not, you need to verify that the is power going to the board at the +9V pad.
If so, double check your wiring from the IN jack to the foot switch and then to the “T” pad at the IN on the main board.
Further assistance will require good photos and voltages.
September 29, 2019 at 9:47 pm #6955Anonymous
GuestSorry, Cybercow. I just stepped on your post. You got there first, so you have the lead! 🙂
September 30, 2019 at 10:59 am #6958
CybercowParticipantWilkie1 – no worries. We can tag-team the assist. You first post-response was a good first step. We just need some more info first. 🙂
September 30, 2019 at 11:15 am #6959Anonymous
InactiveWilki1 the led doesn’t light at all. Gonna work on photos and more details. I’ll take some voltage readings too
September 30, 2019 at 3:43 pm #6960Anonymous
InactiveOk I’ve got 9.24vdc at the 9v pad, at R2, and at the common anode of D5. Also Q1 voltage is D-9.24, G-1.47, S-0.00
September 30, 2019 at 5:31 pm #6962
CybercowParticipantVoltages on the pins of the IC? And can you provide some good clear shots of the solder side of the PCB?
October 1, 2019 at 12:04 pm #6966Anonymous
InactiveIC readings
1-0.00
2-0.30 starts about .47 drains down
3-4.42
4-0.00
5-0.00
6-0.30 same as pin 2
7-9.26
8-0.00
I’m working on more photos. I installed right angle pots so it will be hard to see. I’ll do my best with my phone
October 1, 2019 at 12:06 pm #6967Anonymous
October 1, 2019 at 1:10 pm #6968Anonymous
October 2, 2019 at 10:06 am #6999
CybercowParticipantThanks for the added details. I’m unable see anything obvious. Do you have and know how to use an audio probe?
October 2, 2019 at 10:53 am #7000Anonymous
InactiveYes. That was going to be my next approach
October 2, 2019 at 1:52 pm #7001Anonymous
GuestI believe I see that you have removed all of the pots to take a better picture of the underside of the board. I suggest you take this opportunity to reflow all solder joints. First, remove power and the IC and the transistor
After the reflow process, add power and take new voltage measurements of the IC pins. I believe you are getting power to the IC socket. Pin 4 should be 0V and pin 7 should be about 9V.
Then rebuild the board and retest..
October 3, 2019 at 10:07 am #7009
CybercowParticipantJack – I also noticed that your pots have no insulation\shield between the pot housing and the solder joints on the underside of the PCB. It very important to get some sort of insulation between the this pot bodies and the underside of the PCB.
October 4, 2019 at 11:03 am #7016Anonymous
InactiveI’ve put condoms on the pots before reinstalling them. I also replaced D1and D2 and D6 double checking the polarity. I checked the polarity of D3 and D4 which are correct. Getting voltage from both sides of D3 and D4. Is that normal? I’m really running out of ideas
October 5, 2019 at 12:23 pm #7018Anonymous
InactiveJust noticed that the IC I installed is CA3080AE instead of the CA3130EZ
Would that be the problem? -
