  • #29884
    Hi,
    I completed my first board, the Super Sonic v2. When I turn either the volume or drive knob up, you can faintly hear the fuzzy distortion. But when you turn either up to the max, it makes a loud and unpleasant squealing noise. I’m wondering if maybe my resistors or potentiometers are wrong or bad.
    Any help in troubleshooting this will be appreciated.
    #29891
    I cannot trace wiring from the photo.
    That said the first troubleshooting item might be to re-flow all of your on-board and off-board solder joints. 70% of the time a bad solder joint is the issue. Just hold your iron tip on each joint to reheat and re-flow the solder while keeping some extra solder handy in case it is needed. Make sure any bare back pots are shielded against the back of the board. Triple check your wiring.
