Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › So I know it’s not a pedal question…
- This topic has 3 replies, 3 voices, and was last updated 4 years, 4 months ago by
June 25, 2022 at 5:24 pm #25121
So I’ve been on multiple guitar building websites and received consistently the same general research from their supposed gurus so I figured I would take a stab with the actual wiring geniuses. I’m currently building my first from scratch telecaster and I opted to go HH. What I’d like to do just so I can have the look (and simplicity) of a standard Tele control plate is to use a 4way switch and have the 4th position be both pups tapped and out of phase. Id like to do this without using a push/pull pot. Is it possible? Pups are 4 wire Dimarzio DP100s. Any help would be super appreciated.June 25, 2022 at 8:58 pm #25123
ChuckParticipantI did something similar using some cheap Filtertron clones, a six position rotary switch I got from GuitarElectrinics.com and a PRS-ish wiring diagram also from that site – there are several wiring variations on the site as well. I had to widen the front of the control cavity to fit the rotary switch and make a custom cover (kind of a retro Cowboy/Swoopy thing). You may be able to find a 4-way wiring diagram there as well.
June 25, 2022 at 9:00 pm #25124
CybercowParticipantSammyD – Quite likely it will be difficult to do with a standard 4-way switch. How many poles does it have? Without a push-pull pot (or complex multi-pole, multi-throw switch) to provide that added switching dimension. Look for guitar wiring forums on FB or the web. Maybe try these sites that do all types of pick-up wiring . . . .
Good luck!
July 5, 2022 at 7:29 pm #25267Anonymous
So I got a 5 way multi pole switch and standard pots and what I’m trying to achieve is thispos 1. Neck HB
pos 2. Both coils tapped and out of phase a la Jimi clean tone
pos 3. Neck and bridge HB
pos 4. Both coils tapped a la pos 4 on a strat (not real sure if that’s 1&3 in series
pos 5. Bridge HB
i believe I’ve found the right schematic courtesy of the good folks at dimarzio and have a pic. I definitely realize that I could get more options with a switch or push/pull pots, but I really only care about making the options that I would actually use easy to access. Pic included for someone smarter than myself to point out what I got wrong please ????
