Your Source for DIY Pedal PCBs and NostalgiTone! GuitarPCB Forum GuitarPCB Build Support Series wiring – 2 x 3pdt + 1 bi-colour led
  • #32249
    Hi,
    I’m wiring a boost and main board in series with a bypass footswitch and a boost footswitch with the led on for when the main board is active and then a change in colour when the boost is active – I couldn’t find an exact match on the guides page and pulled the below together from a couple of sources but just wanted to sense check it before I start wiring to see if there is a better way of doing it?
    #32258
    I’m not 100% on what you are trying to do
    I’m assuming you want the boost first going into the main pcb and you don’t want to use the boost independently just the main circuit with or without boost
    The way you’ve got it with the boost active LED left side illuminates bypass the boost and right side illuminates but you’d obviously need the bypass switch active for either side of the LED to light up
