Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › Pro-Grade Aluminum Control Panels
- This topic has 9 replies, 3 voices, and was last updated 8 months, 2 weeks ago by
February 23, 2026 at 6:52 pm #38436
BarryKeymasterI’m excited to introduce: Pro-Grade Aluminum Control Panels (Pre-Drilled).
These precision-cut and drilled aluminum overlays are designed to give your builds a permanent, professional finish—combining clean control labeling with design-forward artwork that makes your builds look intentional, finished, and stage-ready.
Built for Durability
Graphics and labeling are permanently dyed into the aluminum surface with a high-gloss finish for a sharp, wear-resistant result that won’t peel, flake, or lift over time.Easy Installation
Each panel is engineered to install cleanly over standard aluminum enclosures. The panels are held firmly in place using your control hardware.(Actual Product Photo below)
https://guitarpcb.com/product-category/control-panels/
Key Features
• Precision-cut 0.45mm aluminum for a true pro-grade finish
• Pre-drilled holes for knobs, switches, and LEDs
• Clear, intuitive control labeling
• Durable high-gloss surface
• Clean, professional presentationGive your next build the finish it deserves. More project designs coming soon.
February 24, 2026 at 7:58 pm #38443
BarryKeymasterAlready have a drilled and wired pedal build you’re proud of — but want it to look more polished?
Pro-Grade Panels install over your existing pedal build — no rework required.
- Remove the hardware.
- Align the panel.
- Reinstall – Done.
A pro-level finish takes just minutes. Engineered to match the official project drill layout.
Check out the visual guide below to see the full transformation.
February 24, 2026 at 10:58 pm #38451
BarryKeymasterFebruary 25, 2026 at 5:42 pm #38456
BarryKeymasterThese photos are the “Real Deal” from a finished production run.
February 26, 2026 at 2:09 pm #38463TIGER1050
ParticipantI love the Clapton is God panel you should make it optional for the Beano. Do you have one in the works for the Crazy Train also. Great idea. Thanks. I think it makes the build complete.
February 28, 2026 at 11:50 am #38496
BarryKeymasterYou can now purchase the Beano Bundle that you requested.
Also there are multiple variations of these:
Crazy Train
Metal Godz
If you all have any requests I am open to hear them.
February 28, 2026 at 4:44 pm #38502
BarryKeymasterEvery Pro-Grade Aluminum Control Panel I offer is individually produced by me — not mass imported or factory stamped.
For each panel, I:
• Design all artwork myself to ensure a precise fit over the matching NostalgiTone layout
• I use 0.45mm aluminum — thin enough for clean hardware installation without stacking issues.
• Hand dye each panel to order
• Apply protective masking before processing
• Hand cut every panel to final size and form the corner cuts
• Precision drill each hole using multiple bit sizes for exact hardware fit
• De-burr every edge and carefully inspect each piece
• Package each panel in protective shipping boxes to ensure safe deliveryThere is a significant amount of hands-on time in every panel. I produce these in small batches with close attention to fit, finish, and ease of installation so builders can achieve a professional result without compromise.
These panels are built for builders who care about the details.
Each design includes subtle nods and references — see if you can spot the hidden Easter eggs.
March 3, 2026 at 5:57 pm #38548
BarryKeymaster“2112”
Bridge of Sighs
Call of Cthulhu
NostalgiTone 70s
Custom Work Available
I also offer custom panels. If you have dimensions and finished artwork ready, I’m happy to produce a one-off or small-batch order.
If you need assistance with layout or artwork preparation, I can help with that as well for a small design fee.
March 4, 2026 at 8:24 am #38556JasonWickersham
Participant’70s above is AWESOME!!!!
March 9, 2026 at 2:14 am #38604
BarryKeymasterMore added.
John Mayer Tribute
SKYN-TONE Standard Edition
SKYN-TONE “74” Edition
ZOSO Tone
