Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › OD Pedal radio signals (solved)
- This topic has 11 replies, 5 voices, and was last updated 6 years ago by
Big O.
August 29, 2020 at 1:45 pm #14415
InactiveHey guys, I recently opened up one of my overdrive pedal builds and noticed a few solder joints were iffy. I fixed them, but when I put it back together, it started picking up radio static and signals. Any ideas why that might be?
August 29, 2020 at 3:11 pm #14416
BillyModeratorWithout knowing what it is hard to say Drew
Could be a filter cap not filtering out rf noise or poor shielding is it back in it’s box?
There’s a few things internal and external that can cause noise
Did you reflow any capacitor joints
August 29, 2020 at 7:49 pm #14421Anonymous
InactiveUpdate: the radio signal is coming from my amp, not the pedal, but the static sound is for sure coming from the pedal.
Yes, I reflowed most of the joints. It’s the Black Dog. The solder joint that connects the battery snap to the input jack was kinda bad so I re-did it, and I figured that while I was at it I may as well check over everything. Looks like I should have just left everything as is! The static gets more intense when the gain knob is turned up.August 30, 2020 at 7:35 am #14423
BillyModeratorCould just be an audio wire running too close to a power wire Drew
Do the old pencil test get either a pencil or something non conductive and wiggle your wires to see if it affects the noise
Try to place your audio carrying wires as far away as you can from power wires if they have to cross do it like this + not paralell like this =
Does it make the noise when battery powered
August 30, 2020 at 12:01 pm #14432Anonymous
GuestBilly is spot on. Any high gain pedal can pass along RF. It may be coming in through your cable between the guitar and pedal. Or through the guitar pickups. Or through the pedal wiring. Or through the wiring between the pedal(s) and the amp. Investigate these sources.
The Black Dog does have a second order low pass filter that is designed to roll off high frequencies above 7238 Hz.
August 30, 2020 at 7:25 pm #14435Anonymous
InactiveIt’s definitely the pedal. It does it when it’s isolated too. I only hear the noise when that pedal is on. Battery power makes no difference. Moving the wires around didn’t help either.
August 30, 2020 at 7:42 pm #14436Anonymous
InactiveJust noticed something… the solder pad that connects the PCB to the middle lug of the input jack (the lower pad in the IN box) seems to have been ripped off. I’m sure that isn’t helping…
August 30, 2020 at 7:46 pm #14438
BarryKeymasterThat is your ground so that would cause it. Fortunately our boards contain extra ground pads so find a way to get common ground.
August 30, 2020 at 9:00 pm #14439Anonymous
InactiveI switched the ground wire to a different ground pad. It’s still there but it’s less noticeable.
August 30, 2020 at 9:13 pm #14440
BarryKeymasterYou need to go over your entire build and make sure all grounding is good.
Re-flow.
Please post clear pictures and we can advise.
August 31, 2020 at 12:12 pm #14446Anonymous
InactiveGot it. Sounds normal now. Thanks guys!
October 16, 2020 at 5:01 pm #15271
Big OParticipantThe old radio signal problem. I was having the same problem with a couple of my HS treble booster pedals when the boost was dimed and the amp at a fairly loud volume. I changed out the 2n3904 transistors in the pedals to S9013’s and the radio broadcast disappeared. Put the 3904’s back in and I could hear the radio. Why, I for certain don’t know. But switching out the transistors work and I’m not going to argue the point.
