Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › musikding.de Rat deluxe (solved)
- This topic has 16 replies, 4 voices, and was last updated 5 years, 8 months ago by
December 20, 2020 at 8:18 am #16290
InactiveMorning all.
I picked up the Rat deluxe kit to make for a christmas present for a mate, but, Im slightly stumped.
If I connect the guitar, I have a bypassed signal, but if I engage the pedal I get nothing. I tried it on a power supple and a 9v battery.
Id really appreciate it if anyone could cast there eye over this and see is it something glaringly obvious
Thank
December 20, 2020 at 8:18 am #16291Anonymous
December 20, 2020 at 9:39 am #16293
BillyModeratorHi Beasley
Post a picture where we can see and trace your wiring to in and out jacks, dc jack and battery snap
December 20, 2020 at 12:10 pm #16295
BarryKeymasterChip is in backwards I believe.
The dot on the chip represents Pin 1.
December 20, 2020 at 1:46 pm #16297Anonymous
InactiveThe red wire to ground on the top right corner didnt feel right to me but I thought thats what the wiring diagram said, im wondering might that be it
December 20, 2020 at 1:47 pm #16298Anonymous
InactiveNever knew the chip could be backwards. I turned it round but no joy.
December 20, 2020 at 5:26 pm #16302
BarryKeymasterSwitches are not installed. SW1 and SW2.
See Ratt Clipping Chart in build guide and BOM on Page 1 or schematic.
Install the correct switch to the correct pads to complete the circuit.
December 21, 2020 at 12:29 pm #16313Anonymous
InactiveThank Barry, that was an utter brain fart on my behalf. Thanks for your continued help on this. Its melting my head slightly.
Switches now installed, but still no joy. The battery seemed to be getting hot too?
December 21, 2020 at 12:56 pm #16314
BillyModeratorThe battery +9v wire should go to the middle lug on the DC jack you’ve also got your other red +9v wire going to a ground pad on the 3PDT pcb
December 21, 2020 at 2:12 pm #16315Anonymous
InactiveThanks Billy.
Im definitely getting closerIf I connected it to a mains and had the battery connected, she worked, no LED but it worked. I was trying to work out what the deal was with the battery having to be connected to I removed the 9v snap on and Im back to having nothing again.
Im feeling slightly better that it at least made noise this time.
December 21, 2020 at 3:10 pm #16318
BillyModeratorIf you look here you’ll see how the DC jack should be wired
Perhaps have a read through the post also a ratt deluxe
December 21, 2020 at 5:24 pm #16323Anonymous
InactiveYe are legends, each and every one of ye to a man.
Its works! It makes noises! And I put the back on and it works!
The last stumbling block is the led? Iv swapped it round the other way thinking Id it in back to front but no joy.
Any words of wisdom?
December 21, 2020 at 5:37 pm #16324Anonymous
GuestYou are missing a CLR (current Limiting Resistor) on the 3PDT wiring board. Try 1K8 – 4K. Higher resistance = dimmer light. Also I believe you are trying to use a 3 wire bi-colour LED. I believe that board used a standard 2 wire single colour board.
December 21, 2020 at 5:40 pm #16325Anonymous
InactiveBalls.
I must have stuck one in somewhere else wrong so, Iv nothing else left over. Could I use a piece of wire ?December 21, 2020 at 5:47 pm #16326Anonymous
GuestSadly, no. If you try to use a bare wire, you will destroy the LED instantly. The LED must have some resistance in order to survive.
December 21, 2020 at 5:56 pm #16327Anonymous
GuestI know what you did! You installed a 3K3 resistor into R12 on the RATT board. That is your CLR!
You have 2 ways to go now. If you want to have the bi-colour LED, you can remove it from the foot switch board and install it on the main RATT board. You will need to add the wires from S4, S5 and S6 to the footswitch. Then disconnect power from the foot switch board.
Your second choice is to remove the CLR from R12 and install it on the foot switch board. You can then use just one colour of the LED by using just 2 of the LED wires. The middle wire is the anode (+). Clear?
December 22, 2020 at 3:46 am #16336Anonymous
InactiveGreat Success Wilkie!
She works! She’s in and all is right in the world again!
Cheers for all the help -
