  • #22980
    This is one of my cleaner builds.  I’ve checked and re-checked the build docs, but I’m not getting any signal when engaged.  The bi-pass works, and the two color LED works.  Maybe I’m missing something, and the GuitarPCB hive can see something I can’t.
    #22988
    Make sure your in and out cables go to the correct sockets it’s very easy to put your out cable to in socket and visa versa with the box the wrong way up
    You’d still get bypass but no effect
    All components I can see look correct can’t clearly see the resistors at the top of the board or D2
    #23186
    I hadn’t thought about checking the direction of my cables.  That wasn’t the problem unfortunately.  I added a couple more pictures
    #23187
    There’s definitely some differences in the build doc Compared to what I have here. For instance I have a ground running from the foot switch on the output side to the sleeve of the output jack. I’m not sure if that would make this difference though.
    #23188
    It is too difficult to make out where the wiring is going.
    Maybe draw a picture showing us the connections you have made between the IN/Out Jacks and the wiring board and the main board.
    Also you can check for continuity yourself to try and see what is not correct. This guide is for a standard foot-switch wiring but it uses a similar wiring scheme as the wiring board.
    #23397
    I tried to label the off-board wiring the best I can.  Still no signal.  Let me know if you see anything I could try.
    #23398
    At this point, as next steps, I’d un-stuff the guts and examine the solder-side for any solder bridges. Once that is verified, I would apply a signal probe and trace the audio into, thru and out of the main board.
    #23399
    Can you point me to a tutorial to trace the signal with an” probe?
    definitely no solder bridges
    #23403
    Here’s a PDF explaining the audio probe and it’s use etc
    https://drive.google.com/file/d/1T9OsJ0riQhm1QFWPfNQ5q5guikuFKDRN/view?usp=drivesdk
