• This topic has 2 replies, 3 voices, and was last updated 1 year ago by Barry.
  • #37803
    Steve
    I know this question was answered in another thread but thought it needed its own place here for future discussion.
    Thanks to Jeff24 for asking the question.
    Jeff24:
    “Barry: can the PreAmp Boost have the Tight/All Frequencies mod done? Typically I’d be looking for a 10n or 220n capacitor; what needs to be modded, or does it let all frequencies through?”
    Barry:
    “You would need to reduce R1 to 10M (down from 22M) for all suggestions below:
    Preamp Boost assuming (R1 ≈ 10 MΩ) – C1 High-Pass Options
    Treble-focused – 47 nF (159 Hz)
    Strong bass roll-off; tightens low-E strings, very bright tone.
    Tight lows – 100 nF (150 Hz)
    Noticeable bass reduction; low-E fundamental trimmed.
    Moderate trim – 220 nF (73 Hz)
    Slightly tighter low end; low-E lightly affected.
    Subtle trim – 470 nF (34 Hz)
    Minimal low-frequency reduction; almost full guitar lows pass.
    Notes:
    Use film-type capacitors (polypropylene or polyester) for best tone.
    Smaller capacitance → higher cutoff → more low-frequency roll-off.
    Larger capacitance → lower cutoff → fuller bass response.”
    #37806
    Jeff24
    Thank you for creating this new thread.
    I’m hoping this info will make it into the build doc for the PreAmp Boost.
    #37810
    I would like someone to test out that Mod and report back their findings so I can add it.
