Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Help with identifyiing capacitors in P.U.R.P rangemaster build kit please.
- This topic has 16 replies, 4 voices, and was last updated 5 years, 3 months ago by
July 17, 2021 at 2:45 am #19771
InactiveHi,
I’m having some issues Identifying the values of the caps in the PURP’D treble booster kit V3 and where to stick which to where on the pcb.
I would just like to double check rather than remove them after guessing and getting it wrong. I have tried the guide for identifying them but the numbers just seem out to me.
The numbers printed on the caps are ; 382J63, 473J100 & 223J100 (I may have the last one sussed but….)
I am new to this pcb malarkey. O r….. how do I test them
TIA, Doc.July 17, 2021 at 3:16 am #19772
BarryKeymasterGo to the Guides Page for anything you are not familiar with.
There is a Capacitor Code chart for you.
July 17, 2021 at 10:03 am #19773
CybercowParticipantDoc . . . .
382J63 = 3.8nF (3n8F or 0.0038µF) @ 63v (I think you may have a typo – 3.9 is the more common value rather than 3.8. And the PURP does NOT have a 3,9nF or 3.8nF cap – I believe you meant to type 682J63 which is 6.8nF and IS used in the PURP.)
473J100 = 47nF (0.047µF) @ 100v
223J100 = 22nF (0.022µF) @ 100v
And as Barry points out, there is a LOT of information on the Guides Page.
July 17, 2021 at 10:21 am #19774Anonymous
InactiveThanks guys. I appreciate the assistance.
I did have a look at the guides. Like I said, I’m new to this and I had trouble reading it compared to what I have in front of my ‘passed their use by date’ eye balls. Full steam ahead I say!July 17, 2021 at 11:34 am #19776Anonymous
InactiveThe guides are a wealth of info I must say and have helped me heaps. And now for the next question.
In the Q1 pinout which is the emitter, inboard or outboard? I have a PNP germanium transistor with a painted dot over the emitter pin and that’s what I must go by. Yet again I can’t find the correct search terms. My apologies if I’m being a pain.July 17, 2021 at 1:13 pm #19778
CybercowParticipantDoc – here’s the pinout configuration for the PCB . . . .
If you have the PNP germanium transistor from the kit, this should make things simple. If you’re using a different BJT for Q1, we’d need to know what the type (number) it is. What is the type of transistor you’re using?
July 17, 2021 at 8:54 pm #19785Anonymous
InactiveCybercow. Thank you! You have answered my question perfectly!
Marks (Should that be Marx?) /numbers on the transistor are (2 cyrillic letters, a sideways figure 8 and a capital n, 4028807. It looks like a W.W.1 tin hat with 3 legs.
The kit that I bought doesn’t come with any transistors. I bought the V3 P.U.R.P from Pedalparts Australia. Link –
PPA
The story goes, I bought another RM kit from a different local site some months ago, complete with Russian Germanium transistor, the thing didn’t function. I thought I’d ‘blown’ something. I bought another, same outcome. Cut my losses, went elsewhere and found what I assume is a better kit and here we are!
Thanks again Cybercow.August 7, 2021 at 9:09 pm #20156Anonymous
Inactive<hr />
you may want to pick up a capacitance tester for added “security” … dirt cheap and easy to use … note that many multimeters can test for capacitance but a dedicated tester has a much larger range it can test … multimeters start to want when you enter the pico values…
August 7, 2021 at 9:16 pm #20157Anonymous
InactiveThe HoldPeak HP-36D looks identical to the one I have … if it is … it works great but the battery door is a nightmare … less that $20 … can test to low value picos
August 7, 2021 at 9:23 pm #20158Anonymous
Inactivehi Cybercow, what silicon PNP transistor would work for the PURP? Any recommendations? Been scanning datasheets but would like to see what has worked for others …
August 8, 2021 at 3:58 pm #20165
BarryKeymasterGermanium Transistors measured for PURP project here:
August 8, 2021 at 5:53 pm #20167
CybercowParticipantJeremy – “hi Cybercow, what silicon PNP transistor would work for the PURP? Any recommendations? Been scanning datasheets but would like to see what has worked for others …”
I’ve experimented with several different PNP BJTs with the PURP build and they all tend to work to one degree or another. Bias adjustments were needed when changing most of them. I go the best results out of the ones Barry has in stock, cheap Russian MP20B, AC188, NKT275, AC125, AC125, OC44, OC71 and so forth. Most importantly the gain needs to be between 45 and 150 with as low of a leakage as you can find. I even used some silicon PNP BJTs with fair success. The ones Barry has are a slam-dunk.
August 9, 2021 at 9:45 am #20177Anonymous
InactiveThanks for the recs … I picked ip the recommended germanium transistor and will socket it. I’ll experiment with others, including the ones you noted, and will see what happens … thanks again folks
August 9, 2021 at 7:13 pm #20179Anonymous
InactiveHey Barry, is there a reason that there’s no cart in my end of the germanium transistor site that you sell?
August 9, 2021 at 8:10 pm #20182
BarryKeymasterI am not able to replicate an issue. Let me know if anyone else is having an issue.
Let me know if I am missing the issue. see images below.
August 9, 2021 at 8:52 pm #20187
BarryKeymasterDon’t forget to purchase or clear your cart afterwards.
August 10, 2021 at 3:25 am #20192Anonymous
Here’s a screenshot Barry. Off topic but……….I think it may be because I’m in Oz?
