Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Help With Adding an After Burner to GGG TOCT Fuzz
- This topic has 5 replies, 1 voice, and was last updated 4 years, 7 months ago by
April 10, 2021 at 3:15 pm #18130
InactiveI am trying to add an after burner to the octave footswitch of my General Guitar Gadgets TOCT Fuzz
The problem right now is that when I hook up 9V and ground to the after burner, the whole pedal stops working. By that I mean the led doesn’t come on and there is no signal when engaging the pedal. When I measure the voltage across the positive and negative terminals on the DC jack, I get basically nothing. When I disconnect 9V from the after burner, the pedal works again (except for the octave right now of course) and I get the expected 9V across the DC jack terminals. Any ideas?
Here’s a link to the TOCT layout and wiring diagram:
http://www.generalguitargadgets.com/pdf/ggg_toct_lo_dist_f.pdf
Here’s how I have it wired:
I know it’s a bit of a mess. But, the was the first pedal I ever made.
April 10, 2021 at 9:30 pm #18136Anonymous
InactiveI mean After Blaster not After Burner
April 10, 2021 at 10:50 pm #18138Anonymous
InactiveAfter some messing around, I have some new results.
I disconnected the LED wires. Doing this made the pedal operate again.
Then, I moved the wires I had connected to “I” and “O” to “IN” and “OUT”. This gets the After Blaster working.
As of now, the pedal is working and the After Blaster is working, but I have no LED working. Maybe I just cut the jumper I was using for CLR?
April 10, 2021 at 11:13 pm #18139Anonymous
InactiveCutting the jumper I was using for R5 didn’t fix the LED issue. The pedal functions, but no LED for the octave foot switch.
I could really use some help with this.
April 11, 2021 at 12:52 am #18140Anonymous
InactiveWell I figured this out all on my own. Hopefully this will help somebody out in the future.
To get the LED to work, I connected the positive LED coming from the main board to the LED hole on the After Blaster surrounded in white. Then, I connected the LED ground coming from the main board to the opposite end of the LED holes. The middle hole is empty.
April 11, 2021 at 1:03 am #18141Anonymous
InactiveOther build notes
I left R5 unpopulated
I used a 2N5457 for Q1. I found that a 3k resistor for R4 worked to get it within the specified range. I’m getting around 4.6V at Q1 drain.
Everything is working as intended. I’m using a momentary switch for the octave. When I step on it, I get the octave and boost and the LED comes on. I learned a lot from having to solve this by myself. However, I hope this will help save somebody some headaches in the future.
