  • #30739
    Hi,
    I’m about to embark on a DSOTM fuzz as my first build. Am I correct in thinking that R14 is a current limiting resistor for the LED? If I’m wiring the LED to a 3PDT board should I leave R14 unpopulated and instead put that resistor in the CLR spot on the 3PDT board?
    I realise that this is a really basic question but I’d rather ask in advance than mess it up.
    Cheers
    Richard
    #30740
    Yes that’s correct on both points Richard
    Just for info a 3K3 would give you a fairly bright LED most folks use around 4K7 so depending on how bright you like your LEDs you can use any value from 1K8 upwards
    I prefer dim LEDs and use 10K with mine if it’s a standard type LED
    Take your time and enjoy creating your first pedal
    #30742
    Many thanks,
    Yes, I’m going to take my time, and quadruple check everything before I commit to whipping out the soldering iron.
