Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › Dr. Phybes rate LED
- This topic has 6 replies, 4 voices, and was last updated 4 years, 2 months ago by
September 6, 2018 at 11:36 pm #1905
InactiveSo I have built several Dr. Phybes circuits and used the rate LED mod that was detailed in the old forum. However that rate LED gives only an on/off LED at the speed of the phaser. What I would like to know is if there is any way to add a rate LED that pulses rather than just on/off? Looking for something like the rate LED on the EA tremolo, Apollo tremolo, or some other phaser circuits I have seen. Thanks for any input!
September 7, 2018 at 1:11 am #1906Anonymous
GuestI believe this is what you seek:
Rate LED Mod as posted by Tim Shelton
Patrick Garland (words) and Schectadon (picture for Dr. Phybes
1. Solder a Limiting Resistor to the POSITIVE side of the LED (Round) – on Blue LEDs I use a 3k9 Resistor
2. Connect a wire to the Resistor, and solder the wire to 9v
3. Connect a wire to the NEGATIVE side of the LED (Flat)
4. Connect NEG LED wire to lug 3 of Speed Pot
September 7, 2018 at 7:57 pm #1912Anonymous
InactiveThanks, that’s the way I have been wiring it, which works fine and gives a blinking on/off led in time with the rate. I was just wondering if there were a way to wire up a rate led that pulsed from off, growing steadily brighter to on, the steadily darker to off?
September 7, 2018 at 8:03 pm #1914Anonymous
GuestSorry, I don’t know how to design that.
September 7, 2018 at 8:48 pm #1915
BarryKeymasterLEDs can be dimmed in two ways: analog and pulse-width modulation (PWM) dimming. Despite its attractive simplicity, analog dimming can be inappropriate for many applications because it loses dimming accuracy by about 25 percent+ at only 10:1 brightness levels. Pulsing is a more complicated animal.
September 8, 2018 at 12:04 pm #1924Anonymous
InactiveThanks guys. I was hoping there would be just a different place on the Dr. Phybes circuit that I could attach the LED to get that dimming pulse. I will have to consider if I want to just go with the blinking rate LED or tackle the more involved animal that is the dimming pulse LED as outlined above. Appreciate the help!
August 13, 2022 at 7:33 pm #25830Anonymous
Guesttry a large lytic cap in parallel w the resistor. Tc = 1/R*C(something like that 67%) = dlo on, slo off…..
