A DC jack is polarity neutral by itself. How it’s wired determines whether it is negative-center or positive-center. Metal-case DC jacks need not apply – the metal housing always grounds one of the connectors – physically connecting one of the connectors to the enclosure Avoid using metal housed DC jacks.
The de facto standard for “most” stompbox guitar pedals is center negative. I don’t know why as IMO center positive would be better since Cybercow’s concern about metal jacks would go away. If you have a schematic of the circuit of interest, there should be a series or shunt connected protection diode that would give an indication of polarity.
Author
