• This topic has 22 replies, 6 voices, and was last updated 4 years ago by Anonymous.
Viewing 6 posts - 18 through 23 (of 23 total)
  • #24478
    This is hardly imaginable, as the PCB grounded connections should all share a common PCB connection (you can see the little “bridges” from the soldering pads to the common ground).
    #24480
    I know. But why isn’t there a connection between those points all going to ground
    #24483
    Just try to route one of the available ground pads separately to casing ground (or with a clamped connection from one of the existing solder points)
    #24485
    Based on the photo of the solder-side, I would definitely reflow several of those solder joints – several of them look “dry” or incomplete.
    #24498
    I made it work by connecting the islands to common ground with two extra cables.  Broke a germanium diode while trying to clean a hole to use for permanent connection. I’m kind a had it with this build. I’m have no idea how to get the diode out again or clean that ground hole. But the pedal worked. Thinking about just getting another kit and start over. Fixing those tiny boards is close to impossible. Here is a picture of of the extra cables going to the island that is not connected to input output ground either.
    #24499
    Glad it finally worked.  The diodes should not be much of an issue.  You can take them off with a self-heated desoldering pump (e.g.Vellemann VTDESOL3), which also empties the holes and normally leaves the solder pads in place.  New diodes are really cheap to order (I always order some additional ones and keep several types in my DIY box). If you might later want to try different ones it is always a good idea to not solder them directly to the PCB but to use sockets in between.
