  • #16316
    Hello, first off I am new to pedal building and schematic reading.
    Question about the Buff N Blend “R8.” The value reads 1k8, is this the “CLR?” With my limited experience, it appears to be, as far as I can tell from the traces and schematic. If so simply adjust the value to the desired LED being used?
    This is such a practical and useful pcb!
    Thank you for your time!
    #16317
    R8 is the CLR. Any value from 1k to 4.7k.
    The higher the value the dimmer the LED.
    #16319
    Thank you!
