Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › balanced out (XLR)
- This topic has 7 replies, 5 voices, and was last updated 5 years, 4 months ago by
July 17, 2021 at 12:03 pm #19777
InactiveIf I were to want to put a balanced out on a build in addition to the regular output (thinking I could utilize that straight into my audio interface) how hard would that be to add into a circuit? could it just be something added between the output of the board and the output jack? I saw a post from Wilkie1 that mentioned it in reference to the Paramix, but I don’t know if the same would apply here as I’m not using the Paramix in this case. would anyone happen to have a schematic of how to do this?
July 17, 2021 at 1:16 pm #19779
CybercowParticipantMiah – see this other forum thread . . . .
July 17, 2021 at 1:40 pm #19780Anonymous
InactiveCybercow!, That is perfect! thank you!
July 18, 2021 at 9:45 pm #19835Anonymous
GuestI sent Barry a prototype DI box with extra features including balanced XLR a couple of years ago. He did not have many folks interested in it at that time. I will be happy to help if anyone is interested. Here is a photo of the one I made for Barry.
July 18, 2021 at 11:11 pm #19836
CybercowParticipantWilkie1 – that’s sweet!
July 19, 2021 at 4:54 am #19842
BillyModeratorTell us more Wilkie
I particularly like the cab sim addition
But don’t have a clue with DI boxes in general I have had a few people asking about adding xlr etc
July 19, 2021 at 11:28 am #19844Anonymous
GuestI’m interested in this also and have collected a DI pcb and XLR jack and a dual buffer from another store. Occasionally I plug into a friends PA just for home / acoustic fun. parts are stacking up, better get to building.
July 19, 2021 at 7:43 pm #19848Anonymous
GuestHere is some more info. The basic DI circuit is nothing more than a buffer and a final gain stage that has an extra opamp that takes the output and inverts it to provide the extra output needed for the balanced XLR jack. I used the basic circuit that Jack Orman published.
Then I added these features as options: Switch for -15dB input pad, High cut filter, input attenuator pot, -15dB output pad switch, phase invert switch, output level pot, ground lift switch, Marshall 4X12 cab sim switch, bypass 1/4″ jack, Inverted out unbalanced 1/4″ jack, normal out unbalanced 1/4″ jack, balanced out TRS 1/4″ jack, balanced out XLR jack.
I did not add a phantom power switch but that is possible. I used a smaller vero for the cab sim circuit and a larger one for the rest of the design.
I made one of these for a local club sound man. I hope this helps inspire builders!
I
