  • #3208
    Matt
    Hi Barry-
    Under the Direct build Doc list, the Zenith doesn’t show the mods for the pads 1-7. Do you still have those? And is the Zenith still available or has it been mothballed?
    More to the point: I built one a while back, pretty stock and combo’d it up with an apollo trem. Great combo, but I’d like just a touch more grit out of it. I’m using an LED in D2, and running it into a clear pot, so I’d like to keep it. I can see from the schem that pad 5 heads out to the other mods, so what do you recommend I do here? I could wire in an additional diode and an SPDT switch and just loop it in, but what’s the best connectivity point? Thanks!
    #3209
    When looking for a build guide be sure to go to the Mandatory Guides section of the forum.
    Here is the direct link:
    Also in the Guides Section you can find the url to the old archived site.
    If you forget this just add a “.webs” after the http://www.guitarpcb
    Example: guitarpcb.webs.com and it will take you to the old archived site then click on forum and you will find the Layout Gallery. Likewise if you wish to download something you may also be required to add a .webs to the url to avoid getting a url error.
    In short for everyone:
    The .webs after guitarpcb in the url is what separates the new site from the archived site.
    Don’t forget to answer the “GRIT” question this circuit is designed to be what many call “transparent” which is a word I really do not care for as all circuits color the signal or it would be useless but I digress so if you want more “distortion” you may consider an AfterBlaster add-on board and use either J113 or for more distortion sub in a J201.
