Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Zendrive pcb: how to get more gain….
- This topic has 9 replies, 3 voices, and was last updated 1 year, 7 months ago by
March 23, 2025 at 8:36 am #35748
GuestI just built the latest guitar pcb Zendrive… I remember the old original one I had having more gain.. which I liked… it mentions just putting a jumper in place of the LED in the instructions… will this increase gain? Any other ideas to get it closer to the higher gain original Zendrive?
March 23, 2025 at 10:36 am #35749
BarryKeymasterPlease post clear pictures of the top of the PCB that shows resistor band colors.
March 23, 2025 at 12:19 pm #35750Anonymous
March 23, 2025 at 12:19 pm #35751Anonymous
GuestBarry, this is the only picture I have… I built it and gave it to someone…. Can you see what’s going on?
March 23, 2025 at 12:51 pm #35752
BarryKeymasterI wanted to double-check a few things before making a suggestion.
The resistor values look good, so there’s nothing to adjust there.
If you swap the Gain pot for a B1M, you’ll get more available gain. However, keep in mind that maxing everything out could introduce some noise or potential squealing.
March 23, 2025 at 2:28 pm #35753Anonymous
GuestThanks, Barry! What’s would omitting the LED do and just bridging there…would it affect gain?
March 23, 2025 at 2:43 pm #35754
BarryKeymasterThe LED is a clipping Diode. In this case providing asymmetrical clipping. So between the LED and the assymetrical clipping the idea is that it provides a more “Tube Amp” like clipping tone.
The B1M Gain pot will affect the Gain.
March 23, 2025 at 6:47 pm #35761Anonymous
GuestI’ll give the 1M gain pot a try and see how it goes! Thanks, Barry
March 24, 2025 at 3:10 pm #35768
ChuckParticipantI’ve tried different ICs in the Zendrive in the past. While they don’t actually increase the gain, they may add a bit of color that gives the impression of a bit more gain. I’ve got a TL082 and a OPA2134 in different builds as well as the TL072.
March 25, 2025 at 3:00 am #35774
BillyModeratorThis version is exactly the same apart from changing the reverse polarity protection diode to a series 1N5817 which obviously wouldn’t affect gain
The gain of the op amp is provided by resistance in the negative feedback loop increasing that would increase gain as Barry says
The only thing I can’t clearly see is your LED orientation It’s difficult to tell whether you have the cathode flat side going to the flat side of the silkscreen
I’d also double check you have the correct value for the gain pot it’s easy enough to mix them up
March 25, 2025 at 9:42 am #35776Anonymous
GuestThanks for all your help!! I have another kit coming… I’ll dig in soon…
