  • #20912
    I was thinking about trying to do a dual d’lay, but I’m not sure if I can use one tap tempo to set the tempo on both… Does anyone hear have any experience with that? I’ve seen a couple of dual d’lay builds, but I’m not seeing any talk on if they’re using tap tempo with them.
    #20917
    I have a D’Lay and a Tap-Tempo PCB set ready building, but they are in my build queue and not seen the bench yet.
    Looking at the schematics for each, my concern is that with one Tap-Tempo for two D’Lay circuits, would there be a need for DC decoupling between them. I don’t know the TTG-Taptation IC well enough to decide if DC decoupling is required or not. I also do not think there would be any harm in trying. I suggest following the build docs for each and TRY the dual connection to the second D’Lay. AFTER FIRST ENSURING BOTH D’LAY PCBS WORK AS THEY SHOULD WITHOUT THE TAP-TEMPO.
    #20921
    Lol, I’m not opposed to just trying! Sometimes you gotta roll the dice. Thanks Cybercow
