Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › turn knob up, gain goes down. Klon mkc v4
- This topic has 6 replies, 3 voices, and was last updated 4 years ago by
May 18, 2022 at 9:55 pm #24667
GuestG’day team. Working on a Mkc v4 Klon, and have a strange issue.
The Gain 2 pot, which is wired the same and has the same value as the gain 1 pot per the build manual, turns the volume down as the pot is turned up. As I understand it, turning the pot up should increase the clean volume? What am I missing here?
I’ve replaced/rewired the B100k gain 2 pot with another gain 2 pot (in case the pot was bad), and rewired it with fresh wire (in case I botched the solder). A video of what I’m describing can be seen here (Vintage strat into a deluxe Reverb for the tone): https://youtu.be/wQdJnZV8F-I
Knob order on the pedal, top to bottom, gain 1, 2, treble, volume
May 22, 2022 at 12:01 pm #24698Anonymous
GuestShould I wire it backwards? Maybe i misvalued the resistors/caps that occur directly after that pot? You’re our only hope! What would you do?
May 24, 2022 at 11:40 am #24725Anonymous
GuestVery strange.
Flipped wiring or bad pot would be my first thought. Yours too, since you’ve tested both those theories and the problem persists.
I would just switch out the 1 and 3 lug wires. Turning the pot up (CW) increases resistance between lug 1 and 2 and decreases resistance between 2 and 3, turning it down (CCW) vice versa. So flipping the wiring should do the trick.
I’ve built 3 of these v4 Klons in the last week and none had that particular issue. I wonder if any of the wiser members have any other ideas. Let me know how it works out.
May 24, 2022 at 12:33 pm #24726
CybercowParticipantDoesn’t make any sense to me. The green wires are going to lug #1 on the pots and to the #1 spot on the PCB. ??????
May 24, 2022 at 12:46 pm #24727
CybercowParticipantDouble-check the voltage at the “VB” point – where R23, R24 & C18 meet. If that value is not exactly ½ of the voltage supply, goofy things can happen with the gain pots.
May 24, 2022 at 8:10 pm #24738Anonymous
GuestThank you Cybercow and MilitaryMD for the sanity check.
Just got a chance to flip wires on lugs 1 and 3, turns out that did the trick! Unsure why that’s the case, I have one more Klon board, so we’ll see if the same thing happens on the next build.
Case closed!
PS: Sound is killer, check it out- https://youtu.be/NU8f1bX7jak
May 26, 2022 at 11:18 pm #24760Anonymous
GuestGlad to hear it worked out. Great video- the pedal sounds great, and the graphics are top notch too!
