Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › TRIM POT CONFUSION ON STAGE 3 BOOSTER – FIRST EVER BUILD
  • #20554
    Hi I’m currently putting together my first pedal build and I’m confused as to which holes to use as there are 4. The legs of my trimpot fit comfortably into 1, 3 and the un-numbered hole in the middle, but should I be bending to use the hole numbered 2?
    #20555
    The extra hols is for different sized trimpots that may have a slightly different position for the #2 pin. The un-numbered hole in the middle is directly connected to the hole marked as #2. It’s just a convenience accommodation for different sized trimpots.
    #20582
    Ahhhhh, I see! Thank you
