  • #35813
    Nico
    Bonjour, je cherche le schema de la version v3 de la swah, avec les valeurs des composants .
    Où puis-je trouver ça svp ?
    Nico
    Hello, i’m looking for the schematics of the swah v3, can you help me ? Thanks
    Ou bien, si la numérotation des composants est identique, les changements entre la v3 et la v5.
    Or, if the numbering of the components is identical, the changes between v3 and v5.
    #35814
    It is the same. Only cosmetic differences.
    If you want to check the numbering it is here: Swah OLD v3B
    There is an OLD v3 (no B) which has not been available in 9 years that required a single jumper and that was the only difference between v3 and v3B
    #35822
    Nico
    Thank you, Barry. It seems to be the V4 version (it’s written on the pcb ^^) , which is slightly different. Can you also provide me with the associated schematic?
    #35823
    Build Docs are on the Guides Page
    #35834
    Nico
    <p style=”padding-left: 40px;”>Thanks Billy and Barry, merci pour ces précieux renseignements, le projet va pouvoir avancer.</p>
    Cordialement Nico
