So, I decided to build the new SuperLead OD circuit during the Superbowl. Turns out the SuperLead OD circuit is A LOT more exciting than this year’s Superbowl.
The SuperLead is a great addition to anybody’s lineup and I really dig the range of Gain available. It certainly captures that dimed Marshall sound.
I find that the longer I’m building pedals, the slower I go. The more time I take on each solder joint, getting the wires the right length without too much excess but enough play, actually waiting a few days to touch a freshly painted enclosure, double checking parts before soldering, etc. Going slower prolongs the process (which it turns out means more enjoyment – assuming you enjoy soldering, hooking up wire and drilling/finishing enclosures) and also improves results.
This build, I had the circuit, all off-board wiring and enclosure drilled (I needed the enclosure drilled to install the pots as I used right angle pots) and populated all during the somewhat Superbowl. The only part I didn’t finish was the enclosure finish.
The enclosure graphic is actually one that Barry shared a while ago and I though it worked well with a Marshall style OD.
It was fun to build this great circuit in an afternoon and it has been even more fun to play the SuperLead OD.
