Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Sunn Model T pedal getting very very low sound
- This topic has 12 replies, 4 voices, and was last updated 4 years, 5 months ago by
March 23, 2022 at 7:37 pm #23798
InactiveI’m going to go over the soldering on the components again, but I’m not seeing where I’m missing something. Any help would be appreciated.
March 23, 2022 at 10:50 pm #23804
BillyModeratorDo you get effect but just at low volume
If that’s the case I’d start with reflowing the pot solder lugs especially volume lug 2 and treble lugs 2 and 3 some of the pot solder joints look like they may be dry
March 24, 2022 at 12:13 am #23806Anonymous
InactiveI did some resoldering,still not getting real loud…
The interference is because I have my soldering iron plugged in the same strip as the pedal.
March 24, 2022 at 10:14 am #23808
BillyModeratorThere are a few solder joints that visually look dry some also look like the solder hasn’t flowed properly
Before reflowing joints you’re better trying to find where your problem lies
Post your transistor voltages that may help narrow it down
Hopefully you got your J201s from Barry which will guarantee their good
In your video it doesn’t sound like you’re getting much drive did you have gain maxed?
March 24, 2022 at 11:26 am #23809Anonymous
InactiveI had everything maxed out. I biased the j201’s with the trim pots to come out. I didn’t get them from Barry and I’m thinking that might have been part of my mistake. I’ll order them tonight if you think that may fix the issue.
I tried a different solder with this build than my last. I was not a fan of it, so I’ll be switching back to what I’d been using on all my other builds.
March 24, 2022 at 2:53 pm #23813
BillyModeratorMay not be the transistors post the transistor voltages that may give us an idea
Some of your transistor solder joints do look as if they lack solder try reflowing those joints hold your iron on the joints for 4 seconds until you see a nice pool of solder making sure you get a good connection between transistor pin and solder pad allow each pin to cool before doing the next one
I’d wait until you know what it is before changing anything it could be something simple like a dry solder joint
Do you have an audio probe
March 24, 2022 at 6:26 pm #23818
CybercowParticipantTJ – From where did the J201s come?
March 24, 2022 at 8:15 pm #23821Anonymous
Inactive@billy-I don’t have an audio probe yet. I saw some plans to build them online, I’ll probably do that this weekend. I’m still very new to all of this so I’m still getting up to speed.
@Cybercow – they’re bridgold j201’s from Amazon. They had good reviews. Next time I need some extra components I’m just going to order them from Barry with my pcb.March 24, 2022 at 8:58 pm #23822
BillyModeratorIf you’ve got a multimeter take voltages on the transistor pins
Pinout like this
Here’s a PDF for an audio probe
https://drive.google.com/file/d/1T9OsJ0riQhm1QFWPfNQ5q5guikuFKDRN/view?usp=drivesdk
March 26, 2022 at 12:46 am #23838Anonymous
InactiveI built an audio probe and found some areas where there was some weak solder. I tried to reflow them and made some progress but still not sounding like it should.
I’m going to step away from that build for now and revisit it in the future. Thanks to you guys who’ve been helping me get it fixed.
April 21, 2022 at 11:52 pm #24220Anonymous
InactiveResurrecting this old post-
I was poking around with my audio probe and the c9 capacitor (270pf) is loud on one side and quiet on the other. I tried replacing it with a new one but the problem persists.
Any ideas?
April 22, 2022 at 5:46 pm #24225
BarryKeymasterWe need the voltages for all J201 posted.
May 8, 2022 at 7:57 am #24481Anonymous
GuestHey guys. I’m having the same issue. Voltages as follows.
q1. D-4.71. S-.281. G-0q2. D-4.71. S-.266. G-0
q3. D-4.71. S-.227. G-0.
q4. D-9.14. S- 5.25. G- 4.71i biased towards the bottom end of the reccomended spectrum because it seemed to get a bit more volume.
