Delete this post if it doesn’t belong, but I thought it too good not to share. Do you like modding your guitars and their pickups but don’t like making your tiny pickup wires shorter and shorter? Well the DPDT Mod Board can be a good solution. As you know the board has a bundle of pads in each quadrant. Solder your pickup wire to the rear, where they will stay tucked away, and modify to your hearts content with the wires soldered to the front. If you run out just solder a new wire on in an empty pad of the quadrant. The two center holes can be used for mounting and/or ground. I mounted here with picks as insulation in the rear to protect against short circuit. Right now it sports Jimmy Page wiring.
