Let’s try some voltage measurements while you work on replacing the ribbon cable for the reverb switch. You don’t need the IC’s installed yet. With power supplied to the jack. Meter set to DC voltage, ground lead on a known good ground, preferably on a GND pad or jack.
First check is at the DC pad. expect a little over 9v. We don’t want to see -9V.
next check the voltage after D5. that would be on the cathode side or the stripe. Voltage should be slightly lower. This is your VC voltage as labeled in the schematic. No voltage means D5 died saving your project. stop here and replace it.
Now check IC1,IC3 IC4, and IC6 (the 8 pin IC’s) you want to check pin 8 which will be to the right of the index notch. You should have the same voltage as VC
Let us know what you find.
