Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › Rototone Question
- This topic has 13 replies, 3 voices, and was last updated 7 years, 1 month ago by
Big O.
October 8, 2019 at 3:50 pm #7036
Big OParticipantI have a few Rototone boards I purchased awhile ago to use in projects, but haven’t used them yet. I have the original, not the deluxe version.
Can one stack one Rototone board with another for clipping purposes? I would like to use the Rototone for 4 different symmetical clipping diode pairs primarily. I was wondering if I can stack another Rototone with 4 single diodes that goes to the input of the diode pair Rototone board in order to get 20 different types of symmetric or asymmetrical clipping combinations. I would put the single clipping diode Rototone board on a switch so I could add it or take it out of the clipping circuit.
Would adding a single diode (from the switched Rototone board) to the input of the diode pair Rototone board result in 2 diodes in series for the first diode position of the diode pair and therefore providing asymmetrical clipping? I assume the solder pads are connected in a parallel fashion, correct?
October 8, 2019 at 6:03 pm #7039
CybercowParticipantI can never wrap my head around multiple switching configurations without drawing them out on paper first. In your shoes, I’d continuity check the pads and connection points of the Roto-Tone PCBs to be sure of the ins & outs and draw it out. Your concept comes off as sound, and it can likely work if wired properly. I’m reasonably sure it can be done, I’d just draw it all out first.
October 8, 2019 at 8:47 pm #7040Anonymous
GuestI agree with Cybercow. You should draw this circuit out so you can visualize how the switching would work. Post it here if you wish and we will offer our advice. I think I have an idea of what you seek, but I will wait and see what you come up with. 🙂
October 9, 2019 at 4:39 pm #7042
Big OParticipantAsk and you shall receive. I believe below is how one would draw out the schematic.
October 9, 2019 at 7:00 pm #7043Anonymous
GuestThat is exactly what I thought you were contemplating. With the SPDT switch, you have 20 combinations. Without, you have 16.
Bravo! Let us know what diodes you end up using and which combinations pleased you the most.
October 9, 2019 at 7:49 pm #7044Anonymous
GuestBut, I don’t think it will work electrically. The first single diode would be blocking one half of the signal phase from reaching the diode pair. Instead of one half of the signal going through the diodes in the same orientation and the other half of the signal going through the other, you would be blocking one half completely.
October 10, 2019 at 10:16 am #7048
Big OParticipantWilkie, you are absolutely correct. Duh, on my part! The switched single diodes preceding the diode pairs would act as a half rectifier. I suspect there is really no way using the Rototone to add or subtract a diode to the diode pairs to effect a switched asymmetrical/symmetrical clipping situation. I believe even running the the single diode and diode pair Rototones in parallel rather than in series wouldn’t work either.
October 10, 2019 at 12:20 pm #7049Anonymous
GuestI have an idea for a solution. I’ll sketch it out and post shortly.
October 10, 2019 at 1:08 pm #7050Anonymous
October 10, 2019 at 1:40 pm #7051
Big OParticipantThanks for your input. I already thought of that one. I wanted something a little more versatile. I can’t think of any other way to do it, unfortunately. I don’t know if the symmetrical/asymmetrical switching does much anyway, since to my ears most dirt is dirt. I must have at least 20-30 dirt pedals and listening and comparing one to another (which I have done in the past) there doesn’t seem to be a lot of difference, except maybe for some of the more crazier fuzz sounds. But when it come to OD and Distortion pedals, there doesn’t seem to be a whole lot of difference to me when it comes to the basic dirt of the pedal, although the different circuits tend to color the sound in different ways.
October 10, 2019 at 2:29 pm #7052Anonymous
GuestThis is a good exercise for all of our readers. I agree that the differences can be subtle. If you try 20 different combinations, you may narrow that down to 3 or 4 that you will use. This type of switching is very useful for the selection process. I think Barry probably has the best ears for discerning the subtle differences.
October 19, 2019 at 1:33 pm #7131
Big OParticipantI found my original concept schematic for the clipping. It is different from what I originally posted. I don’t know if this would work, but it puts a 3rd diode in parallel to ground along with the original two clipping diodes. See below.
At the time I thought this would give similar clipping to #1 and #2 on a single Rototone as below (borrowed image). I don’t know if this would accomplish assymetric clipping or not, because it looks like to me when the 2nd single diode Rototone is switched into the circuit it would place 3 diodes to ground similar to what I assume is position #2 below.
October 19, 2019 at 2:41 pm #7132Anonymous
GuestYou are correct. Assymetric clipping means exactly what it says. The number of diodes in both directions are different. i.e. you may have 2 going in one direction and 1 (or3) pointed in the other direction.
Your switching above does that by adding a diode to the parallel set thus creating a 1 to2 assymetric clipping set. Well done!
October 19, 2019 at 3:09 pm #7133
Big OParticipantI know the switching I drew out isn’t exactly accurate, but I just copied the old drawing I had to show the general scheme of what I was trying to accomplish. Now I hope to get this thing built sometime this winter, but have a lot on the plate right now and don’t know when I am going to get around to it.
Basically an electra distortion with diode clipping variations mated with a paramix in order to mix in a clean with dirty signal. Sort of what EVH does with his stage setup according to what I have read. He supposedly blends a dirty amp with a clean amp to keep some articulation along with the distortion.
