Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › Show Off Your Build › Red Ranger Special (Red Special & Tone TwEQ)
- This topic has 16 replies, 9 voices, and was last updated 5 years, 9 months ago by
Cybercow.
November 28, 2020 at 2:29 pm #15973
CybercowParticipantOn average I have a rather good build success rate – about 12 out of 13 builds work the first time. In this “Red Ranger Special” build, I combined a GuitarPCB “Red Special” with a GPC “Tone TwEQ” and combined the two circuits, leaving the tone section out of the Red Special – but left the Red Special volume pot in place as a 10-turn 100K trimmer for fine adjustment if needed. (The 100K trimpot is shown in the schematic, but sits between the Red Special and the Tone TwEQ after the 470nF (C5) cap.) The resultant schematic looks like this:
I also added 1N5817 protection diode add the +9v int to the Red Special board and used a 10K pot (instead of 5K) for the Sag control. After spending much time in planning out the build, I found I had to try a few different layout plans to get everything to fit into 125B enclosure. Using a bit of non-conductive foam, I settled on what you see in the images below . . . .
After completing the wiring, (as shown in the gutshot below), I fired it up and started test things out. Bypass worked fine, but engaged, the circuit was for intents and purposes dead. I could only hear a very faint signal coming thru with absolutely no change in anything when adjusting the controls.
Thinking I only needed to adjust the JFETs bias control, I flipped the pedal over to make an adjustment to the bias trimmer, when the DC power cord slipped out. The pedal suddenly came to life – but none of the controls worked. So, I put it back in bypass mode (still with no power) and the signal was true. Then, with the powers supply still unplugged, I hit the stomp switch and there was no change. I had signal but no control over anything and no “effect”.
Puzzled and disappointed, I was troubled by what I had done wrong. All that careful planning; examining the adjusted component omissions, the wiring between the two main PCBs, the 5-pots PCB, the stompswitch wiring PCB and DC supply. Everything looked perfect. Thinking I has possibly place the 100K trimmer in backwards, I turned it fully counter-clockwise to see if that was the issue. But alas – no change and the pedal continued to behave the same way.
I considered dissembling the whole thing, when I then thought to first check ALL the voltages and continuity of the DC supply paths. All the +9v lines were correct and supply voltages where needed. I even checked the Sag control and found it working properly. Next, I started checking the ground connections where everything was looking perfect – until I tested the two main PCB grounds to the ground on the DC jack. I had neglected to supply a ground wire to the either of the two main PCBs, but had indeed supplied a ground wire between the two boards.
I grabbed a small piece of black wire and connected the 3P2T wiring board to the Red Special board and fired it up again. BINGO! Wow! What a circuit! The gain is thru the roof and the sag control gives that “sputtery” sound of a dying battery; sounding more like a fuzz pedal.
I also learned that the Sage control is best left at the original 5K value as 10K does nothing after the center point. So, instead of changing out the pot, I just dropped a 10K resistor across lugs #1 & #3 of the pot, (basically converting it into a C5K pot), and called it good.
I highly recommend the Red Special and Tone TwEQ combo build. The added active tone controls add tremendous dimension to the pedal. Now, all that’s left is finish a couple other builds and get to decal day. Here are the pre-decal and Photoshop mockup of the finished artwork for the candy wrapper . . . . .
Thanks for looking. Happy building!
November 28, 2020 at 3:33 pm #15975
BarryKeymasterWow that is a great story! Thank you for sharing such a well thought out presentation. It looks fantastic! I am glad you added the Tone TwEQ and may this be a reminder to others to incorporate the Tone TwEQ wherever you can. The Tone TwEQ is also considered a Mod Board and is part of our Bulk Discount Deals.
I think the story also clearly shows none of us are perfect so to certain posters Please Share Photos for quicker troubleshooting. As opposed to saying “I built it correctly but it doesn’t work” with no photos attached.
I appreciate the candor.
November 28, 2020 at 5:46 pm #15977
BillyModeratorExcellent looks superb Mark
I’ll be sure to try your mods when I build mine
November 28, 2020 at 6:57 pm #15978Anonymous
GuestYep! I was going to say the same things that Barry did! There is a lot of valuable lessons to learn herein. Another master build by a Master Builder. Bravo Cybercow!
December 9, 2020 at 1:14 pm #16137
Big OParticipantThis thread demonstrates the challenges of more complex builds. Even very experienced builders have problems at times. I can say in the last couple of years building a few pedals using all or one or two GuitarPCB boards I have really upped my game in problem diagnosis and solving skills. I have two pedal building sayings from my own experiences.
First – Build. Build. Build, for experience.
Second – If something can go wrong, it will go wrong every now and then. Just expect it.
December 9, 2020 at 2:02 pm #16138Anonymous
GuestWhat a great build and story. I have a lot to learn. Where would one get some of that super handy foam?
December 9, 2020 at 3:55 pm #16139Anonymous
GuestI salvage foam like that from all of the packages my wife orders from Amazon. But I also highly recommend the new Gum Wadz Barry offers in the SHOP. Fantastic stickum and insulation!
December 9, 2020 at 5:40 pm #16141
CybercowParticipantJon – Thanks for the kind comment. The foam is just a random piece of foam I had stashed away just for such purposes. I collect little bits of shipping\packaging foam from things I receive in the mail. That particular piece came from metal curtain rods packing that my sweetie ordered. Like Wilkie1, I save bits of packing material and use Exacto knives to re-shape them when necessary.
I considered using some of Barry’s Gum Wadz material that I ordered last month, but it called placing these to PCBs back-to-back and I didn’t want to go there. I now use the Gum Wadz stuff for small PCBs and other sticky predicaments.
And thanks Big O! Your two points sum up a lot.
December 12, 2020 at 10:18 pm #16203
CybercowParticipantAnd here’s the finished Red Ranger Special pedal . . . .
This one is destined for my pedalboard. Really like the Brian May tendencies.
December 29, 2020 at 9:55 pm #16444
PollyWollyCrappyParticipantThat looks amazing! I’m attempting pretty much the same build myself so this post is going to be super helpful, especially regarding the bypass of the tone and volume. I doubt mine will be quite as shiny, though. Did you make the daughter board for the 9mm pots yourself, or is there somewhere I can purchase one of those? I’m wondering if I can do something like that on vero.
December 29, 2020 at 11:21 pm #16446
CybercowParticipantPollyWolly – Thanks! Those 5-pot PCBs can be found at SmallBear . . . . .
Good luck with your build!
December 30, 2020 at 4:19 pm #16454
Barry W DavisParticipantAwesome build!
December 31, 2020 at 5:11 pm #16464
PollyWollyCrappyParticipantThanks! I was putting together an order for Small Bear and didn’t even know they had those.
December 31, 2020 at 6:33 pm #16465
BarryKeymaster
January 1, 2021 at 11:49 am #16473
CybercowParticipantBarry – Sweet! Thanks!
HAPPY NEW YEAR!
February 18, 2021 at 8:56 pm #17221
ChrisParticipantReally awesome build!! I love using the TwEQ! Very elegant and clean inside as well, I really admire your builds!
February 19, 2021 at 1:40 pm #17232
CybercowParticipantChris – Thanks! Barry supplies some great building blocks for enhanced ideas.
