Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Ratt Deluxe question
- This topic has 16 replies, 8 voices, and was last updated 3 years, 7 months ago by
mybud.
January 22, 2023 at 11:15 am #27435
GuestHey guys is there a build document to do the Ratt Deluxe sans “Deluxe” option? Just a standard build??
Thanks!
January 22, 2023 at 1:49 pm #27438Anonymous
GuestYou can build this version without the Ruetz Mod and eliminate the SW1 and SW2 switching. In that case, you would use clipping diodes only in D1 and D2. But, to make it as original as possible, you would also need to change other component values. I Googled an original schematic that showed many values that varied slightly. Compare the two schematics.
Unless you built 2 RATTs using one as original stock values and a second one built stock as the V4 with all of its switching options, you will never know which one/settings sounded better to you. Your choice.
January 22, 2023 at 6:39 pm #27440
BillyModeratorHere’s the older V2 build doc showing original components
https://drive.google.com/file/d/1uYPJ3Xy4PkEpZeyWUt-l5G5aVWGdA7kN/view?usp=drivesdk
January 28, 2023 at 1:47 pm #27491Anonymous
GuestThanks fellas!
February 7, 2023 at 1:03 pm #27592Anonymous
GuestHey guys, one more question.
When shopping for these capacitors how do I determine what I need based on this list? Online everything is uf or nf and this list just has n or p or u. What is what?220n
10n
22p
100p
470n
330n
220n
3n3
220n
220n
47uThanks in advance!
February 7, 2023 at 1:37 pm #27593Anonymous
Guest220n = .22uF 100pF = .1nF = .0001uF
Check out the handy GPCB Capacitor Chart here:
https://guitarpcb.com/community/topic/pedal-building-guides-mandatory-reading/
February 7, 2023 at 1:38 pm #27594Anonymous
Guestyou’re seeing different units of the same values. like kilometers to meters but in microfarad (uF), nano-farad (n), pico-farad (p), etc. i use this utility to double-check my conversion … http://www.unit-conversion.info/capacitance.html
February 7, 2023 at 2:30 pm #27595
BarryKeymasterI also am sending out postcards currently with orders that has this conversion table + codes on the back.
February 7, 2023 at 3:58 pm #27598Anonymous
GuestThanks Guys,
February 25, 2023 at 6:05 pm #27807Anonymous
GuestHey Guys one more question. What am I looking for when searching for the SPDT on-off switch and the SPST switch..? Can you provide a link for each for example perhaps?
Thanks!
February 25, 2023 at 8:12 pm #27810Anonymous
GuestIt seems you have missed a lot of good information. Go to The Guides Page and scroll down to the the Beginner’s Guide to Components. When you scroll down through that listing you will find a detailed explanation of switches.
February 25, 2023 at 8:48 pm #27811Anonymous
GuestLol omg I knew that was there and totally forgot about it. Thanks.
March 21, 2023 at 10:01 am #28034Anonymous
GuestHey fellas,
Me again. I finished the build it sounds great. I had an enclosure laying around that I’m using temporarily but wanted to ask what size enclosure is recommended for the Ratt Deluxe? Looks like a lot of folks on the forum are using what looks like a 125B??? Any reccomendations?
Thanks,
MC
March 21, 2023 at 1:46 pm #28037
SteveModeratorI put mine in a 125b enclosure… see attached photo for a gut shot.
The 125b to me is perfect because you are not cramped for space.
March 21, 2023 at 2:21 pm #28038Anonymous
GuestNice. Thanks for the response.. That’s the way I was leaning just wanted to double check.
March 23, 2023 at 11:05 pm #28063Anonymous
GuestWhile we are talking about this, can someone show me a picture of how the old LM308 can sits in 8 Dip socket?
Greatly appreciated.
Nik
March 24, 2023 at 9:41 am #28065
mybudModeratorThere’s info on this over (LM308 can to 8pin dip socket) at Beavis Audio.
Look for 4 knob Ratt.
