  • #40861
    e_man
    I hope this is the correct place to post this question.
    Upon completing the V1 Copper (one of the bonus PCBs offered), I found the circuit generated a high frequency noise most prominent when the volume and gain controls were set above 50%.
    Some research suggested that a 1054 charge pump may eliminate the noise.  It did not.  I have tried both the 7660SC and the 1054CP (the 1054 was noisier).  I don’t have any 1044s on hand.
    Running the circuit at 18v solves the noise problem, but prevents me from combining it with a couple of other circuits for a triple combo I had in mind.
    Are there any components that could be changed to eliminate the noise?
    Any guidance would be appreciated.
    Thanks.
    #40879
    e_man
    SOLVED!
    I noticed in the build document that a 1044sc was recommended for this circuit.  I searched my collection of ICs and discovered a 1044sc.  So I installed the 1044sc and voila’! no noise!
    #40882
    Glad you saw that, and thanks for reporting back. The 1044SC is the right charge pump for that board.
    To be clear, I did not design or build any of the Free Bonus boards from that short run. I only knew they were verified and made sure they made sense schematically, and offered them as a free bonus to encourage a few small purchases, while I worked through getting NostalgiTone phase 3 ready for launch.
