Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › Post Fuzz boosting/buffering
- This topic has 1 reply, 2 voices, and was last updated 7 years, 5 months ago by
May 30, 2019 at 11:05 am #5952
InactiveHi,
There seems to be a new couple of manufactured pedals that provide some type of distortion, then a second post distortion boost of some kind, sometimes triggered internally, sometimes by purchasing an external second footswitch which plugs into a jack on the pedal.
I know the shop here sells post-effect booster circuit boards and buffers.
Then there is the school of thought that the fuzz sounds best unbuffered, at the start of the guitar chain, then all other effects.
My question then is: is there a general way to have an unbuffered fuzz circuit first in chain when activated, but buffered when bypassed, and second question, if one of the boosts was placed directly after the fuzz circuit on another foot switch, can it simply make the fuzz even louder without changing the character of the fuzz (for emotional emphasis for example on the outro of a tune)?
Has anyone made such a build or set of pedals, and are there links to either vids or builds?
Could I put two boosters after a fuzz and keep making it louder without changing the nature of the sound?
Thanks!
May 30, 2019 at 1:12 pm #5954Anonymous
GuestI’ll make an observation here and then I’ll wait for Barry to elaborate on what he found when he did an extensive evaluation of his pedal board.
The traditional thinking on a fuzz pedal is to place it first in line after the guitar since the pickups are a higher impedance than a buffer output. In other words, it sounds better.
After the fuzz, you can then add other pedals to perform tasks such as adding distortion, compression, delay, tremolo, phase shifting, etc. Typically, you want to maintain a unity level as the signal passes through each pedal until you reach the end of the chain. This is where most folks that wish to overdrive the front end of their amp would add an additional boost or overdrive to raise the final signal level. This final boost or the last pedal in the chain also provides a low impedance signal which can drive long cable runs and matches nicely with the front end of the amplifier. This is also a perfect place to add a Solo switch feature to provide two volume levels for featuring the guitarist in the mix. You don’t need two buffers to do this.)
If you follow the above sequence of pedals, you will not alter the tone of the fuzz when it is activated except for changes made downstream. When it is bypassed, the next pedal in the chain will take the guitar signal and modify it with its effect before sending it out through its low impedance output. (Most pedals are designed with a high impedance input stage and a low impedance output stage which is what a buffer has.)
I yield the floor to Barry and others.
